StarTech.com Solid Wire Cat 6 Modular Plug
£15.50
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Allows you to easily terminate your Cat 6 cable to the exact length required
  • Designed to fit all Cat 6 Patch Cables
  • Colour: Clear
  • Stock Status: In Stock
Product codes
This Cat 6 RJ45 Modular Plug can be used with Cat 6 bulk cables, allowing you to easily terminate your Cat 6 cable to the exact length equired.
Product Description StarTech.com Cat 6 RJ45 Modular Plug for Solid Wire - 50 Pack (CRJ45C6SOL50) - network connector - clear
Type Network connector - CAT 6
Packaged Quantity 50 (specifications are for single item)
Connector RJ-45 - male
Colour Clear
Designed For P/N: WIRC6CMPBLU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Solid Wir...
£15.50
