Convert a Digital Coax or Toslink Signal to Stereo RCA Audio. The SPDIF2AA Toslink/Optical SPDIF to RCA Audio Converter lets you convert a 2-channel Digital Coaxial or Toslink/Optical SPDIF input signal into an RCA analog stereo output.
Perfect for home and professional audio applications, this SPDIF to RCA audio converter saves the cost of upgrading equipment for compatible connections, and offers separate Digital Coax and Toslink inputs for dual-function conversion. The small form factor design makes it suitable for installation into virtually any location, regardless of space constraints, while still providing a lossless audio signal. Plus, the digital coaxial or Toslink to RCA converter supports plug-and-play installation, saving you time and hassle.
Product Description | StarTech.com SPDIF Digital Coaxial or Toslink Optical to Stereo RCA Audio Converter - Digital Audio Adapter (SPDIF2AA) - coaxial/optical digital audio converter | Product Type | Coaxial/optical digital audio converter | Product Material | Steel | Dimensions (WxDxH) | 4.2 cm 2.7 cm | Length | 5.2 cm | Weight | 78 g | Colour | Black | Manufacturer Warranty | 2-year warranty | Designed For | P/N: FLATPNLCEIL, FLATPNLWALL, FPCEILPTBLP, FPCEILPTBSP, FPWARTB1M, FPWARTB2, FPWFXBAT, FPWTLTBAT, STNDMTV100, STNDMTV70, STNDMTVDUO, SVA5M3NEUA |
General | |
Width | 4.2 cm |
Height | 2.7 cm |
Length | 5.2 cm |
Weight | 78 g |
Colour | Black |
Connections | |
Connections | Digital audio input (coaxial) - RCA , Digital audio input (optical) - TOS Link , Audio line-out - RCA x 2 |
Manufacturer Warranty | |
Service & Support | 2 years |
Compatibility Information | |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
