StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Dupli...
£341.80
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Duplicate one 2.5/3.5" hard drive to another without connecting to a computer, or backup multiple drive images to a library drive to restore PC/Server images easily. The SATDUP11IMG standalone SATA hard drive duplicator, lets you create an exact duplicate of a SATA hard drive (HDD) / solid state drive (SSD), or create a single backup library drive containing multiple images you can copy to additional drives at any time.
Reduce clutter with the SATDUP11IMG eliminating the number of drives required when creating backups of multiple unique drive images. Using a single backup library drive, you can store several unique drive images on a single SSD / HDD, ensuring fast duplication at 6 GBpm and minimal clutter. This is an ideal solution if you frequently re-image different computer systems, because it means you'll only have to carry a single backup library drive to restore multiple drive images onto different systems.
The versatile duplicator also offers standard one-to-one drive duplication in three different modes: file & system copy, all partitions copy and whole copy. This is ideal for one-time drive duplication, eliminating the hassle of creating a drive image for a one-time project.
With an easy-to-read LCD display and intuitive four-button menu operation, the SATDUP11IMG ensures hassle-free setup and control. The menu gives you push-button access to many value-added features that ensure simple task management such as: drive to drive duplication, drive to Image library backup and restore, and many more. It also provides numerous advanced setup options for experienced users.
The SATDUP11IMG is TAA compliant.
Product Description StarTech.com Standalone 2.5 / 3.5" SATA Hard Drive Duplicator w/ Multi HDD / SSD Image Backup Library - Hard Drive Duplicator - 6 GBpm (SATDUP11IMG) - hard drive duplicator
Device Type Hard drive duplicator
Colour Black
Installed Devices / Modules Qty 0 (installed) / 2 (max)
Supported Drives SATA-600
Localisation North America, United Kingdom, Europe
Built-in Devices Status LCD
Storage Controller SATA (SATA 6Gb/s)
Power AC 120/230 V - 50/60 Hz
Dimensions (WxDxH) 13 cm x 8 cm x 3 cm
Weight 350 g
Designed For P/N: SVA12M5NA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Standalon...
£341.80
