StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card...
StarTech.com StarTech.com 2-Port 10Gbps USB-A/USB-C PCIe Card -USB 3.1
£46.12
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • HIGH PERFORMANCE: USB 3.1 Gen 2 or USB 3.2 Gen 2x1 PCIe Add-On card supports Multiple INs, maintains max bandwidth even when mixed speed devices are connected; 10Gbps per port; 1x USB-A & 1x USB-C
  • POWER: Expansion card w/ SATA power supplies supplemental power to the USB ports (when motherboard power is insufficient) providing up to 5V 3A/15W via the USB-C port & 5V 0.9A/4.5W via the USB-A port
  • MAX PERFORMANCE WITH USB DEVICES: 2-port USB-A & USB-C PCIe card adapter supports USB Attached SCSI Protocol (UASP) optimizing USB performance w/ external storage devices like SSDs, HDDs, NVMe drives
  • COMPATIBILITY: Installs in full or low-profile PCIe 3.0 x4 desktop/server slot (lower performance w/PCI-e 2.0); Windows/Linux/macOS auto driver install (Windows 8 & up); Works with USB 3.2/3.1/3.0/2.0
  • THE STARTECH.COM ADVANTAGE: StarTech.com offers a 2-year warranty & free lifetime 24 hour support on this dual port USB-A & USB-C PCI Express Host Controller card w/ full & low profile bracket incl.
  • Wired / Wireless: Wired
  • Protocol: USB 3.1
  • Type: USB adapter
  • Stock Status: In Stock
Product codes
Marketing description is not available.
Product Description StarTech.com 2-Port 10Gbps USB-A & USB-C PCIe Card, USB 3.1 Gen 2 PCI Express Type C/A Host Controller Card Adapter, USB 3.2 Gen 2x1 PCIe Desktop Expansion Add-On Card, Windows/macOS/Linux - Full/Low-Profile - USB adapter - PCIe 3.0 x4 - USB-C 3.1 x 1 + USB 3.1 Gen 2 x 1
Device Type USB adapter
Form Factor Plug-in card
Interface (Bus) Type PCI Express 3.0 x4
Ports USB-C 3.1 x 1 + USB 3.1 Gen 2 x 1
Dimensions (WxDxH) 8.1 cm x 12 cm x 1.9 cm
Weight 48 g
Data Link Protocol USB 3.1
Data Transfer Rate 10 Gbps
Processor 1 x ASMedia ASM3142
Compliant Standards USB 1.1, USB 2.0, USB 3.0, USB 3.1 Gen 2
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux 3.5 to 4.11.x LTS versions, Microsoft Windows Server 2019, Apple macOS 10.13 - 10.15
Designed For P/N: S251BMU313, S251BPU313, S252BU313R
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£46.12
