StarTech.com StarTech.com Digital Signage Display Stand - Bla...
StarTech.com StarTech.com Digital Signage Display Stand - Black - Locking
£1,046.66
Delivery:
Standard: 1-3 working days
Key features
  • Built-in cabinet with lock protects your video equipment from theft and tampering
  • Heavy-duty steel TV mount supports up to 175 lb. (80 kg)
  • Hook-and-mount design for easy setup with VESA compliant TVs
  • Integrated cable management allows for clean installation
  • Stock Status: In Stock
Product codes
Portrait Kiosk Enclosure Steel For 45" to 55" Displays. The digital signage stand provides a convenient and cost-effective way to communicate with clients. Engineered with a sleek and sturdy design, the portrait kiosk enclosure provides a secure mount for a 45" to 55" TV (with maximum weight of 176 lb./80 kg) that will attract and captivate passersby.
Durable Construction
The digital signage mount features durable construction which makes it ideal for commercial use, in environments such as trade shows and retail establishments. While many kiosks have a built-in display, the LCD advertising stand display allows you to repurpose an existing display or one of your choice. Built-in cable management keeps your cables organized and hidden from view. The digital signage kiosk enclosure features a lockable cabinet for installing your computer, media player or video extender.
Easy Assembly
The flat TV stand features a solid base that provides the display with stability, perfect for use in areas with heavy traffic. The base of the touch screen kiosk stand is designed to be bolted to the floor to provide greater stability than freestanding display kiosks.
The Choice of IT Pros Since 1985
StarTech.com conducts thorough compatibility and performance testing on all our products to ensure we are meeting or exceeding industry standards and providing high-quality products to IT Professionals. Our local StarTech.com Technical Advisors have broad product expertise and work directly with our StarTech.com Engineers to provide support for our customers both pre and post-sales.
This DSIGNAGESTND is backed by a StarTech.com 5-year warranty and free lifetime technical support.
Product Description StarTech.com Digital Signage Display Stand - Black - Locking - floor stand
Product Type Floor stand
Dimensions (WxDxH) 35 cm x 96 cm x 194 cm
Weight 40 kg
Recommended Use LCD display
Recommended Display Size 45"-55"
VESA Mounting Interface 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight 80 kg
Colour Black
Package Content 4 x M5x14 screws, 4 x M6x14 screws, 4 x M8x30 screws, 8 x spacers (small), hex key (4mm), 2 x cable ties, hex key (5mm), 4 x M8x50 screws, hex key (6mm), 2 x screws, 4 x rectangular washers, 2 x M4x6 screws, 8 x spacers (large), 4 x M8x60 screws, 8 x M6x15 screws, 2 x end caps, lower base board, 2 x lower columns, 4 x lower column caps, cabinet, upper base board, upper column (left), upper column (right), 2 crossbars, 2 brackets, cable bracket, 2 x locking brackets, 2 x cable clips, 2 x screw caps, 4 x M10x25 screws, 10 x M6x12 screws, 4 x M8 nuts, 2 x M6x35 screws, M6/M8 wrench, floor anchor
Manufacturer Warranty 5-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com StarTech....
£1,046.66
