StarTech.com Stereo RCA to SPDIF Digital Coaxial and Toslink...
StarTech.com Stereo RCA to SPDIF Digital Coaxial and Toslink Optical Audio Converter
£53.14
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Works as a converter and/or splitter allowing you to use one output or both at the same time
  • Accessory Type: Misc
  • Colour: White
  • Stock Status: In Stock
Product codes
Convert a Stereo RCA Audio signal to Digital Coax and Toslink. The AA2SPDIF Stereo RCA to SPDIF Digital Coaxial and Toslink Audio Converter lets you convert or split your analog stereo audio into 2-channel Digital Coaxial and Toslink output signals.
Perfect for many home and professional audio applications, this RCA to digital audio converter saves the cost of upgrading equipment for compatible connections, by offering a separate Digital Coax and Toslink output. For added versatility, the device can also function as an audio splitter using the digital coax and Toslink outputs simultaneously. The converter features a small form factor design that makes it suitable for installation into virtually any location regardless of space constraints, while still providing a lossless audio signal at distances up to 5 meters (15 feet). Plus, the converter supports plug-and-play installation saving you time and hassle.
Product Description StarTech.com RCA to SPDIF Digital Coax and Toslink Optical Audio Converter - coaxial/optical digital audio converter
Product Type Coaxial/optical digital audio converter
Colour White
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Stereo RC...
£53.14
