StarTech.com Tablet Stand - Desk/Wall Mount
£35.77
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Universal tablet stand supports a wide range of tablets and phones, from 4.7" to 12.9"
  • Tablet arm pivots +170 degrees at base, -40 / +180 degrees at elbow, and rotates 360 degrees for portrait or landscape viewing
  • Includes optional base for wall or surface mounting
  • Large square base for stability
  • Supports weight capacity of 2.2 lb. (1 kg)
  • Stock Status: In Stock
Product codes
Increase productivity by mounting your tablet on your desk, to a wall, or under a cabinet. Integrate your iPad or other tablet seamlessly into your workspace, with this universal tablet stand. Move the tablet arm up or down, and rotate the tablet to adjust your viewing position instantly. The tablet stand rests securely on your desk, or you can mount it to a wall, or on the underneath surface of a cabinet or cupboard.
With this highly adjustable tablet stand, you can maximize use of your tablet without having to hold it in your hand or place it down on your desk.
Simply move the tablet arm up or down, with its two movable joints, to position your tablet at the perfect height. The tablet arm pivots 0° / +170° at the base and -40° / +180° at the elbow, to allow easy adjustment of the tablet positioning. Switch easily from portrait to landscape position, with 360° rotation.
The clamp spreads apart easily to hold a tablet or phone from 4.7" to 12.9" in size, and up to 1 kg (2.2 lb.) in weight. With its large base, the tablet stand rests securely on your desk, counter or other flat surface. A smaller base is also included, which lets you mount the tablet stand to a wall, or on the bottom surface of a work cabinet or kitchen cupboard, for a wide range of applications.
Product Description StarTech.com Universal Tablet Stand - Portable Tablet Stand w/ Optional Wallmount Base - Adjustable Pivoting Tablet Stand (ARMTBLTDT) - mounting kit - adjustable arm - for tablet
Product Type Mounting kit (adjustable arm) - wall-mountable
Mounting Components Wall plate, stand base, knob, base cover
Dimensions (WxDxH) 16 cm x 16 cm x 35 cm
Rotation 360°
Adjustments Height, lift
Weight 1.4 kg
Recommended Use Tablet
Recommended Display Size 4.7"-12.9"
Max Load Weight 1 kg
Material Plastic, aluminium
Package Content Hex key (4mm), hex key (3mm), hex key (2.5mm), 2 x screws, 2 x concrete anchors
Manufacturer Warranty 5-year warranty
Designed For P/N: DK30CHPH, STSCART
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£35.77
