StarTech.com Thunderbolt 3 Dock with USB-C (USB 3.1 Gen &...
StarTech.com Thunderbolt 3 Dock with USB-C (USB 3.1 Gen & Gen 2)
£204.42
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • FULLY THUNDERBOLT 3 & USB-C HOST COMPATIBLE: This plug-and-play Thunderbolt 3 docking station works with
  • your TB3 or USB-C (USB 3.1 Gen 2) host laptops, tablets and smartphones
  • DUAL 4K DISPLAYPORT FUNCTIONALITY: This TB3 dock offers dual 4K 60Hz support on Thunderbolt 3 laptops while providing either 1080p or single 4K 30Hz setup dual monitor options for USB C (10Gbps) host devices
  • 60W POWER DELIVERY + ALWAYS-ON CHARGING: The universal Thunderbolt 3 dock charges your laptop w/ 60W Power Delivery, using the included 135W power adapter, reserving 75W to fully power all downstream ports at the same time. Always-on charging ports charge smartphones & tablets even when laptop disconnected
  • ESSENTIAL PORTS: The TB3 & USB 3.1 Gen 2 dock offers 3x USB-A (including one fast-charge)
  • 2x USB Type C Ports (including one fast-charge)
  • 1x GbE Port
  • 1x 3.5 mm Audio/Mic Port
  • 1x K-Slot for Cable Security Lock
  • EASY TO INSTALL & SET UP: Plug-and-play right out of the box with no?time-consuming driver installations required; 0.7m Thunderbolt 3 Certified host cable included and built-in mounting holes for flexible setup
  • Stock Status: In Stock
Product codes
For the first time, there is a plug-and-play Thunderbolt 3 docking station that intelligently adapts to your Thunderbolt 3 or USB-C (USB 3.1 Gen 1 and Gen 2) laptop offering optimal performance and compatibility. This revolutionary technology offers IT professionals the solution they need - one dock for Mac and Windows laptops that are equipped with a USB Type-C port.
With this dedicated dual DisplayPort Thunderbolt 3 dock, you can turn your TB3 or USB 3.1 (Type-C) laptop into a dual-monitor workstation, including dual 4K60Hz resolution on Thunderbolt 3 laptops.
Simply connect the dock to your laptop with the included Thunderbolt 3 cable and start working immediately. With easy plug-and-play installation, the dock is ready to go as soon as you connect it, saving you the time and hassle of installing additional drivers or software.
For more installation flexibility, you can use StarTech.com mounting brackets (SSPMSUDWM & SSPMSVESA) that are specifically designed for the docks and hubs, to mount your TB3 dock to a desk, wall, or other surface to give you the customized setup you need.
If you require more security, the built-in K-Slot uses a traditional laptop combination cable lock to ensure your dock stays put.
This universal Thunderbolt 3 dock (TB3) features plenty of USB 3.0 ports to accommodate up to five USB peripherals and includes a GbE port and audio support: 3 x USB-A Ports (including 1 x Fast-Charge Port); 2 x USB-C Ports (including 1 x Charge Port); 1 x Gigabit Ethernet Port; 1 x 3.5 mm Audio/Mic Port .
The USB-C ports and one of the USB-A ports will support up to 10Gbps (USB 3.1 Gen 2) data transfer speeds, when the host laptop supports the same.
Using a single cable, the dock powers and charges your laptop with 60W Power Delivery, using the included 135W power adapter. The USB-A and USB-C charge ports can charge your smartphone, tablet or other USB peripherals whether you're working or away from your desk, and even if you disconnect your laptop.
Note: Not all USB-C ports support the full functionality of the USB Type-C standard. Ensure that your laptop USB-C port supports DP Alt Mode and USB Power Delivery.
Product Description StarTech.com Thunderbolt 3 Dock w/ USB-C Compatibility - Dual Monitor 4K60Hz DisplayPort Laptop Docking Station - 60W PD, GbE, 5x USB Hub - TB3 / USB 3.1 Gen 2 10Gbps Dock - Windows & Mac - docking station - DP
Product Type Docking station
Docking Interface USB-C 3.1 / Thunderbolt 3
Video Interfaces DP
Dimensions (WxDxH) 22 cm x 8 cm x 3 cm
Weight 250 g
Colour Black, space grey
Localisation United Kingdom, Europe
Networking Gigabit Ethernet
Power Power adapter 135 Watt AC 120/230 V
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Thunderbo...
£204.42
