N/A. This certified Thunderbolt 3 docking station is a compact mini dock, delivering essential connections for productivity. The bus-powered dock connects dual 4K DisplayPort displays, Gigabit Ethernet, and one USB-A (USB 3.2) port and for flexible set up, the attached Thunderbolt 3 cable has an extended length of (11 in./ 28 cm).
Create a Dual-4K 60Hz Workstation
Great for editing 4K video or other Ultra HD tasks, this portable Thunderbolt 3 to DisplayPort dock supports 40 Gbps of throughput and 4K resolution at 60Hz on dual HDMI monitors, through a single Thunderbolt 3 port. Run resource-demanding applications on two independent displays without draining system resources.
Connect your laptop to:
2x 4K DisplayPort (DP) displays (up to 4096 x 2160p @ 60Hz)
Compact Size & 11-Inch Attached Host Cable
At just 2.4" x 4.9" (6.1 cm x 12.4 cm), this dock takes up minimal room on your desk and in your laptop case. The dock's 28 cm (11 inches) attached cable provides extended reach to reduce port/connector strain on MacBooks and laptops on riser stands, or if needed, offers the flexibility to position dock further away from the laptop on your desk.
The Ports You Need Most
1x USB 3.2 Gen 1 Type-A port (5 Gbps)
1x Gigabit Ethernet port (with PXE Boot and Wake-on-LAN support)
Ideal for Power-Demanding Workstation Setups
As many high powered, later generation laptops optimally require more than 100W of power to stay charged, some users prefer to use their laptop's power adapter vs. using their docking stations to keep laptops charged.
This bus-powered TB3 mini dock is ideally suited for those users, providing full Thunderbolt 3 docking station performance and functionality, while their workstation laptops are separately charged."
The TB3DKM2DPL is Thunderbolt Certified and backed by a StarTech.com 3-year warranty and free lifetime technical support.
Product Description | StarTech.com Thunderbolt 3 Mini Dock - Portable Dual Monitor w/ DP 4K 60Hz - 2X USB-A Hub (3.2/2.0), GbE - 28cm Cable - TB3 Multiport Adapter - Mac/Windows - Upgraded Version of TB3DKM2DP (TB3DKMDPL) - docking station - Thunderbolt 3 - 2 x DP - GigE | Product Type | Docking station | Docking Interface | Thunderbolt 3 | Video Interfaces | 2 x DP | Dimensions (WxDxH) | 6.9 cm x 12.4 cm x 2.7 cm | Weight | 148 g | Colour | Black & silver | Networking | Gigabit Ethernet | Power | Power Provided | Manufacturer Warranty | 3-year warranty |
General | |
Width | 6.9 cm |
Depth | 12.4 cm |
Height | 2.7 cm |
Weight | 148 g |
Enclosure Colour | Black & silver |
Video | |
Max Resolution Details | 4096 x 2160 - 60 Hz |
Networking | |
Data Link Protocol | Ethernet, Fast Ethernet, Gigabit Ethernet |
Expansion / Connectivity | |
Interfaces | 1 x Thunderbolt 3 - 24 pin USB-C , 2 x display / video - DisplayPort output - 20 pin DisplayPort , 1 x USB-C 3.2 Gen 1 - 9 pin USB Type A , 1 x network - 10Base-T/100Base-TX/1000Base-T - RJ-45 |
Miscellaneous | |
Cables Included | 1 x Thunderbolt 3 / USB-C cable - integrated - 28 cm |
Features | Preboot Execution Environment (PXE) support, 4K Ultra HD |
Compliant Standards | RoHS, WEEE, RCM |
System Requirements | |
OS Required | Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Apple OS X 10.10 Yosemite, Apple OS X 10.11 El Capitan, Microsoft Windows 7 / 8.1 / 10, Apple macOS Sierra 10.12, Apple macOS High Sierra 10.13, Apple macOS Mojave 10.14, Apple macOS Catalina 10.15 |
Manufacturer Warranty | |
Service & Support | Limited warranty - 3 years |
Dimensions & Weight (Shipping) | |
Shipping Width | 13.9 cm |
Shipping Depth | 19.5 cm |
Shipping Height | 3.7 cm |
Shipping Weight | 300 g |
Environmental Parameters | |
Min Operating Temperature | 5 °C |
Max Operating Temperature | 40 °C |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
