StarTech.com Thunderbolt 3 USB Controller
£201.73
Delivery:
Standard: 1-3 working days
Key features
  • Multi-channel USB 3.1 hub controller with independent, dedicated ports sharing 20Gbps bandwidth
  • Connect up to four high-performance USB devices with one USB-A (10Gbps), one USB-C (10Gbps) and two USB-A (5Gbps) ports
  • Charge your smartphone using the always-on USB-A fast-charge port
Product codes
Convert your laptop's Thunderbolt 3 port into multiple USB controller ports, with one USB-C and one USB-A port supporting 10Gbps, plus a daisy-chainable TB3 port. This Thunderbolt 3 to USB 3.1 controller adapter offers twice the performance of a traditional 4-port USB 3.1 hub, enabling you to connect a wide range of devices to your Thunderbolt 3 laptop. With dedicated USB buses, the controller adds four USB ports - two USB-A (5Gbps), one USB-C (10Gbps) and one USB-A (10Gbps).
The two 10Gbps ports are useful for accessing high-performance, bandwidth-hogging devices such as storage arrays, 3D scanners, audio-video capture and broadcast devices, and external SSD drives. The Thunderbolt 3 port can also be used for connecting a second 10Gbps USB-C device.
When only one port is being accessed, the full dedicated 10Gbps is available. If both 10Gbps ports are being accessed at the same time, the bandwidth being provided to each device will be 5Gbps.
The two 5Gbps ports can provide 5Gbps of bandwidth to each device simultaneously, making it ideal for devices such as portable hard drives. You can also connect low-bandwidth devices such as USB flash drives.
The front USB-A port supports both data and charging. The adapter does not need to be connected to a Thunderbolt 3 computer in order to charge your mobile devices.
The adapter features a second Thunderbolt 3 port that you can use to connect an additional display to your laptop (a USB-C video adapter may be required). The port can also be used to connect additional Thunderbolt devices, daisy-chaining up to six devices in all.
StarTech.com Thunderbolt 3 USB 3.1 Multi-Channel Hub Controller - 10G /5G - docking station
Docking station
Docking Interface
USB-C 3.1 / Thunderbolt 3
7.4 cm x 14.8 cm x 2.35 cm
1.102 kg
Black, silver
Australia, Japan, New Zealand, United Kingdom, Europe, North Asia
Power adapter AC 120/230 V
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Thunderbo...
£201.73
