StarTech.com Thunderbolt to GbE + USB 3
£95.82
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 1 x Gigabit Ethernet & 1 x USB 3.0 port (5 Gbps), through a Thunderbolt connection
  • Compact and durable case design with an integrated Thunderbolt cable, for maximum portability
  • Supports Thunderbolt data rates of up to 10 Gbps, with 2 dedicated PCI Express lanes
  • Plug-and-Play installation on supported operating systems using native drivers
  • Ethernet port supports 10/100/1000 Mbps connections, full-duplex operation
  • USB 3.0 port supports UASP
  • Silver sandblast finish with rubberized grips, matching Apple MacBooks
  • Bus-powered - no external power required
  • Wired / Wireless: Wired
  • Protocol: Ethernet, Fast Ethernet, Gigabit Ethernet, SuperSpeed USB 3.0 + 2 more
  • Form Factor: External
  • Compatibility: Mac, PC
  • Type: Network adapter
Product codes
Add a Gigabit Ethernet port and a USB 3.0 hub port to your Thunderbolt -equipped MacBook or Ultrabook . The TB2USB3GE Thunderbolt to Gigabit Ethernet + USB 3.0 Adapter lets you expand your MacBook or laptop connectivity through a single, compact adapter with both Gigabit Ethernet and USB 3.0, delivering reliable performance, connection possibilities and rugged portability.
Experience fast, effective and reliable performance from your essential peripherals! Leveraging the 10Gbps bandwidth of your Thunderbolt port for this dual-purpose adapter gives you reliable 1Gbps Ethernet and 5Gbps USB 3.0 connectivity, while enabling you to use both to their full capacity.
To maximize efficiency, the Thunderbolt adapter separates traffic from each interface into its own dedicated 5Gbps PCI Express lane, effectively avoiding bottlenecks when both ports are in use. This practical adapter gives you fast, robust external connectivity, offered by revolutionary Thunderbolt technology.
Take full advantage of your current peripherals! Saving you the added expense of purchasing new devices, the adapter lets you simultaneously connect your existing devices through your Thunderbolt port. Combining Thunderbolt to Ethernet and Thunderbolt to USB 3.0 functionality into a single adapter gives you two essential interfaces that are unavailable or limited on most Thunderbolt-equipped systems, making it easy for business users and home users alike to stay connected.
Whether you're in a boardroom with a weak WiFi signal, or in a hotel with only a wired network connection, this adapter has you covered. Plus, the USB 3.0 port (with UASP support) can be used to connect a storage device, USB hub, USB printer, or sync with your tablet or smartphone.
Get work done on the go, and look great doing it! A rugged and travel-friendly design lets you tuck the adapter neatly into your laptop bag, plus the lightweight casing merges portability with durability to offer quality protection that lets you take the adapter anywhere.
The sleek and stylish adapter aesthetically matches your MacBook Pro or MacBook Air, with a silver sandblast finish and black rubberized grips. Plus, the compact adapter requires no external power, and integrates a built-in Thunderbolt cable as well as hassle-free plug-and-play installation.
Product Description StarTech.com Thunderbolt to Gigabit Ethernet plus USB 3.0 - Thunderbolt Adapter - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type Thunderbolt
Ports Gigabit Ethernet + USB 3.0
Dimensions (WxDxH) 8.1 cm x 4.85 cm x 2.05 cm
Weight 92 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, USB, 100Mb LAN, GigE, USB 2.0, USB 3.0
Compliant Standards IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x, IEEE 802.3az
Colour Silver
System Requirements Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.8.4 or later, Windows 10 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Thunderbo...
£95.82
