StarTech.com Tool-Less 2B Mounting Bracket
£5.78
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Easy, tool-less drive installation
  • Wide compatibility
  • Designed for trouble-free use
  • Stock Status: In Stock
Product codes
Install two 2.5" solid-state drives or hard drives into a single 3.5" bay in a desktop computer. Install your drives in no time - with no tools required. This tool-less mounting bracket lets you mount two 2.5" solid-state drives or hard drives into a 3.5" bay in your desktop computer.
The bracket design lets you quickly secure your drives into the mounting bracket, without using tools. Then you simply put the bracket into a 3.5" drive bay in your computer and hold it in place using the tool-less pegs.
Designed for versatility, the tool-less mounting bracket supports a wide range of 2.5" solid-state drives or hard drives, ranging from 5 to 12.5 mm in height.
The lightweight mounting bracket is designed for trouble-free, reliable performance.
Product Description StarTech.com Dual 2.5" SSD/HDD Mounting Bracket- 3.5" Drive Bay -Tool-Less - storage bay adapter
Device Type Storage bay adapter
Colour Black
Supported Form Factor 3.5" to 2 x 2.5"
Expansion Bays 2 x internal - 2.5"
Compatible Bay 1 3.5"
Product Material Plastic
Dimensions (WxDxH) 13.2 cm x 10 cm x 2.95 cm
Weight 52 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Tool-Less...
£5.78
