StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HD...
StarTech.com Travel A/V Adapter: 3-in-1 mDP to VGA / DVI / HDMI Converter
£39.61
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ensure compatibility with virtually any display with three-in-one adapter converting Mini DisplayPort to VGA, HDMI, or DVI
  • Maximize portability when traveling or at the office, with a small foot print, and lightweight design
  • Stock Status: In Stock
Product codes
Connect a Mini DisplayPort-equipped PC or Mac to an HDMI, VGA, or DVI Display. This travel adapter lets you connect your mDP enabled Ultrabook or laptop computer to any VGA or HDMI display. The 3-in-1 Mini DisplayPort adapter is the perfect accessory for your Microsoft Surface Pro 4, Surface Pro 3, Surface 3 Surface Pro 2 or Surface Book.
Why carry multiple adapters when you only need one? Instead of keeping three different adapters on-hand, the mDP travel adapter offers VGA, DVI and HDMI outputs, so you'll be able to connect from your laptop mDP output to any modern boardroom or classroom display - an ideal plug-and-play solution for BYOD (Bring Your Own Device) applications at the office.
Plus, because the converter supports video resolutions up to 1920x1200 or 1080p you can convert a Mini DisplayPort video source to HDMI, VGA or DVI without sacrificing video quality.
The travel A/V adapter maximizes portability with a small footprint and lightweight design. The convenient design ensures the adapter is as portable as your laptop, fitting easily into your laptop bag or carrying case and eliminates the need to carry more than one adapter. With this adapter you can walk into virtually any boardroom ready to present, making a great first impression, and saving you the embarrassment of having to rummage through your bag looking for the right connector.
The 3-in-1 converter is compatible with the Intel Thunderbolt port on your computer and installs easily with no software or drivers required.
Product Description StarTech.com 3 in 1 Mini DisplayPort Adapter - 1080p - Mini DP / Thunderbolt to HDMI / VGA / DVI Splitter for Your Monitor (MDP2VGDVHD) - video converter - black
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x DisplayPort input - Mini DisplayPort , 1 x HDMI output - 19 pin HDMI Type A , 1 x VGA output - 15 pin HD D-Sub (HD-15) , 1 x DVI-D output - 24+1 pin digital DVI
Dimensions (WxDxH) 10 cm x 4.5 cm x 1.5 cm
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Travel A/...
£39.61
