StarTech.com Triple Monitor Stand - Steel
£184.90
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Work with greater comfort and productivity
  • Rugged steel construction
  • Easy installation
Product codes
This free-standing triple-monitor stand saves you valuable desk space, while creating a more comfortable and ergonomic workspace. Constructed of high grade steel, the sturdy monitor stand suspends monitors above your desk or other work surface.
StarTech.com Triple-Monitor Desktop Stand - Articulating - stand (adjustable arm)
Stand (adjustable arm) - stand mountable
Mounting Components
End caps, pole, base plate, crossbar, washers, screws, collar, 2 monitor arms, VESA mount bracket, 2 thumbscrews
30 cm x 141.2 cm x 46.3 cm
Rotation
360°
Adjustments
Height, pan, tilt
7 kg
Recommended Use
3 monitors
Recommended Display Size
13"-27"
Flat Panel Mount Interface
100 x 100 mm, 75 x 75 mm
Max Load Weight
8 kg
Material
Plastic, aluminium, steel
Package Content
M4x12 screws, hex key (3mm), hex key (5mm), hex key (6mm), M5x12 screws, 2 x mounting-arm caps
5 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Triple Mo...
£184.90
