StarTech.com TV Cart for 32"-70" Displays
£366.69
12 in stock
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Create a mobile media center with this TV cart, supporting a 32" to 70" flat-screen TV. This portable TV cart makes it easy to create a mobile media center, providing a convenient and cost-effective way to share A/V equipment between rooms. Engineered with a sleek and sturdy design, the TV cart provides a secure mount for a 32" to 70" TV (with maximum weight of 66 lb./30 kg) and a removable multi-media shelf for placing your computer, media player or keyboard. It also includes a camera shelf for web-conferencing.
The mobile TV cart saves you the cost of buying multiple flat-panel TVs. Simply roll the TV cart between boardrooms, classrooms and meeting rooms, to share your media equipment. The cart features a small footprint that enables you to stand close to the display, while delivering a presentation. You can also set up a display in your lobby during special events or set up a permanent display in areas where you can't wall mount. The wheels are lockable for stationary use.
With the TV cart's spring-assisted height adjustment, you can raise or lower the display mount with one smooth motion, from a minimum height of 3.6 ft. (1110 mm) to a maximum height of 4.9 ft. (1510 mm) - a lift of up to 15.7 in. (40 cm). The TV mount rotates up to 90°, so you can change the position of your display from landscape to portrait. You can also tilt your TV +5° to -12°, to find the optimal viewing angle.
The TV cart's durable construction makes it ideal for commercial use, in environments with multiple users and frequent movement between meeting areas. Built-in cable management keeps your cables organized and hidden from view.
Product Description StarTech.com Heavy Duty Rolling Portable TV Cart Stand with Wheels - 32 to 75 inch - Adjustable Rotating Mobile Flat Panel Screen Mount (STNDMTV70) - cart
Product Type Cart
Dimensions (WxDxH) 82.8 cm x 70 cm x 214 cm
Tilt -12° to 5°
Lift 40 cm
Rotation -90° to 90°
Adjustments Height
Weight 25.1 kg
Recommended Use Plasma or LCD TV
Recommended Display Size 32"-70"
VESA Mounting Interface 200 x 200 mm, 400 x 200 mm, 400 x 400 mm, 600 x 400 mm, 300 x 300 mm
Max Load Weight 30 kg
Material Plastic, aluminium, steel
Colour Black, silver
Wheels Qty 4
Package Content 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 4 x washers, 8 x spacers (small), hex key, 4 x end caps, 4 x M8x50 screws, 6 x M6x8 screws, 4 x M8x25 screws, wrench, left leg, right leg, left cover, right cover, support plate, column, connecting plate, camera shelf, plastic cover, left/right support brackets, column cover, multimedia shelf, 3 x cable clips, 2 x crossbars, 2 x hook and loop ties, 4 x M6x16 screws, 2 x M6x25 screws, 2 x support plate nuts, 3 x countersunk screws, 2 x M4x6 screws, 10 x M6x14 screws, caster wrench, 4 x shelf spacers, 4 x TV washers, 8 x spacers (large)
Manufacturer Warranty 5-year warranty
Designed For P/N: HDMIPLATE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com TV Cart f...
£366.69
