StarTech.com TV Wall Mount - Fixed
£56.59
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Heavy-duty TV wall mount fits most 60" - 100" TVs up to 165 lb. (75 kg)
  • Fixed TV mount for consistent viewing angle
  • Fits curved TVs, with compatible VESA mount
  • Type: Wall mount
  • Stock Status: In Stock
Product codes
Save space and create an impressive display by wall-mounting a large TV in a boardroom or customer-facing area. This fixed flat-screen TV wall mount securely supports a TV up to 100" and features an attractive low-profile design.
Mount your large flat-screen TV in a location that's convenient for visitors, clients and employees. Create an engaging display to keep guests informed or entertained, ideal in lobbies, lecture halls, restaurants, health care centers and other meeting spaces.
The television wall mount supports most 60" to 100" (812.8 to 1778 mm) LED or LCD flat panel TVs weighing up to 165 lb. (75 kg). It also supports curved TVs, with a compatible VESA mount up to 900x600.
Save space with this slim TV wall mount. With its low-profile design, your TV sits just 1.2" (30.5 mm)from the wall.
The heavy-duty TV mounting bracket securely supports your large flat-screen TV and is easy to install. The spring locks allow quick attachment and release. The open architecture provides ventilation and easy access to wires.
Product Description StarTech.com Heavy Duty Commercial Grade TV Wall Mount - Fixed - Up to 100” TVs (FPWFXB1) - wall mount
Product Type Wall mount
Dimensions (WxDxH) 62.5 cm x 95.4 cm x 3.05 cm
Weight 3.5 kg
Recommended Use TV
Recommended Display Size 60"-100"
VESA Mounting Interface 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 600 x 400 mm, 300 x 200 mm, 600 x 600 mm, 800 x 600 mm, 900 x 600 mm, 300 x 300 mm
Max Load Weight 75 kg
Material Plastic, steel
Colour Black
Package Content 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 8 x spacers (small), 6 x concrete anchors, 4 x M8x50 screws, 4 x rectangular washers, 2 x vertical brackets, 8 x spacers (large), level, 6 x washers, 6 x wall screws
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com TV Wall M...
£56.59
