StarTech.com TV Wall Mount - Steel
£154.75
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Save space with this flat-screen TV wall mount for 32" to 70" TVs (fits curved TVs, with compatible VESA mount)
  • Full-motion capability with arm extension up to 20.4" (517 mm)
  • Maximum viewing flexibility with a dual-arm design and +90 /-90 degree swivel
  • Type: Wall mount
  • Stock Status: In Stock
Product codes
Free up space by mounting your flat-panel TV on a wall, with full-motion adjustment capability. Maximize space while creating an impressive display. With its dual-arm design, this heavy-duty TV wall mount securely supports large flat-screen TVs up to 70". The arms are easy to extend, to provide smooth, full-motion positioning for ideal viewing.
Mount your flat-screen TV in a location that's convenient for visitors, clients and employees, and frees up valuable space. The wall mount is ideal for the lobby, boardroom or other venues, providing an impressive and secure way to display a large flat-panel TV or create digital signage. The TV wall mount supports most 32" to 70" (812.8 to 1778 mm) LED or LCD flat panel TVs weighing up to 99 lb. (45 kg).
The TV wall mount provides full-motion adjustment capability. The dual-arm extends up to 20.3" (517 mm) from the wall to provide a wide range of movement and accommodate different screen positions and angles. The dual-arm can also fold to tuck-in closely to the wall, providing a low profile that enables your display to be positioned just 2.24" (57 mm) from the wall.
The TV wall mount swivels +90° / -90° to provide maximum viewing flexibility. The mount also tilts +5° / -8°, letting you angle your TV display toward your audience. With the tilt feature, you can mount your TV lower or higher than eye level and still view it comfortably. A built-in level adjustment also offers 5° clockwise and counterclockwise turning, to ensure your display is perfectly level.
The robust steel TV wall mount, with its dual-arm design and dual-stud mounting for studs placed 16" apart, provides increased durability and security. It safely and securely supports your flat-screen TV, to protect your investment. The TV wall mount also includes built-in cable management to keep cables neatly out of sight.
Product Description StarTech.com Full Motion TV Wall Mount - Articulating - Supports 32" to 70" TVs/Displays - Flat Screen TV Wall Mount - Wall Mount TV Bracket - Steel (FPWARTB2) - wall mount
Product Type Wall mount
Tilt -8° to 5°
Pan -90° to 90°
Adjustments Levelling, swivel
Recommended Use TV
Recommended Display Size 32"-70"
VESA Mounting Interface 200 x 200 mm, 400 x 300 mm, 400 x 200 mm, 400 x 400 mm, 300 x 200 mm, 300 x 300 mm, 400 x 600 mm
Max Load Weight 45 kg
Material Plastic, steel
Colour Black
Package Content 4 x M5x14 screws, 4 x M6x14 screws, 4 x M6x30 screws, 4 x M8x30 screws, 8 x washers, 4 x M8x50 screws, 4 x bracket screws, 4 x nuts, 2 x mounting screws, 16 x spacers, 6 x screws, 6 x concrete screws, 6 x bracket washers
Manufacturer Warranty 5-year warranty
Designed For P/N: HDMIPLATE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com TV Wall M...
£154.75
