StarTech.com Two Way Digital Coax to Toslink Optical Audio Co...
StarTech.com Two Way Digital Coax to Toslink Optical Audio Converter Repeater
£50.01
Delivery:
Standard: 1-3 working days
  • Type: Signal Converter
  • Stock Status: In Stock
Product codes
Convert an SPDIF audio source signal to Digital Coax and Toslink either separately or simultaneously. The SPDIFCOAXTOS Two way Digital Coax to Toslink Audio Converter Repeater lets you extend and convert digital coax to Toslink audio, or Toslink to digital coax.
This small form-factor coax toslink converter is an easy to use solution allows you to select the input signal you want to convert or extend, and simultaneously outputs both digital coaxial and Toslink audio signals without downgrading the audio signal, and provides an output signal that matches the quality of input audio, supporting 2 to 5.1 channel audio.
Product Description StarTech.com Two Way Digital Coax to Toslink Optical Audio Adapter Repeater - coaxial/optical digital audio converter
Product Type Coaxial/optical digital audio converter
Colour White
Manufacturer Warranty 1-year warranty
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Two Way D...
£50.01
