StarTech.com U.2 to PCIe Adapter -SFF-8639
£32.66
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Boost your system speed and performance
  • Easy to install
  • Stock Status: In Stock
Product codes
Get ultra-fast data access by adding an NVMe U.2 SSD to your computer. This U.2 to PCIe adapter lets you add a high-speed, U.2 NVMe SSD to a PC with an available PCI Express expansion slot. You can mount the PCIe U.2 drive directly onto the adapter, giving you an easy and convenient way to improve your system performance and expand overall internal storage.
Product Description StarTech.com U.2 to PCIe Adapter for 2.5" U.2 NVMe SSD - SFF-8639 - x4 PCI Express 3.0 - interface adapter - Ultra M.2 Card - PCIe 3.0 x4
Device Type Interface adapter - plug-in card
Bus Type PCIe 3.0 x4
Colour Red
Hard Drive Form Factor Compatibility 2.5"
Interface Ultra M.2 Card
Supported Devices Solid state drive
Max Storage Devices Qty 1
Dimensions (WxDxH) 2.2 cm x 16.5 cm x 12.2 cm
Weight 65 g
Designed For P/N: BNDTB10GI, BNDTB1394B3, BNDTB210GSFP, BNDTB310GNDP, BNDTB410GSFP, BNDTB4M2E1, BNDTBUSB3142, TB31PCIEX16, U2M2E125
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com U.2 to PC...
£32.66
