We’re really sorry but we currently have no stock of this product. You can either register below using 'Notify Me' and we will email you when we get more stock, or you can browse alternative items we have available today. Just a small point to note - they might not have the exact features as the product you initially wanted so please be sure to check the details before you buy.
Maximize your workspace. This under-desk CPU mount frees up floor and desk space, and gives you easy access to your computer tower.
The under-desk CPU holder provides an easy way to mount your computer under any desk or flat surface. It helps keep your work space neat and organized, by mounting your computer case off the desktop or floor, away from dust and dirt. The under-desk PC mount is ideal for mounting your CPU under a standing or sit-stand desk, moving the CPU up and down along with the desktop as needed.
The heavy-duty CPU holder has an adjustable frame that supports a variety of PC cases, ranging in width from 4.84" to 9.96" (123 mm to 253 mm) and height from 14" to 21.9" (357 mm to 557 mm).
Offering a full 360-degree swivel, the under-desk PC mount provides easy access to your computer case, front and back, ensuring ports and cables are easy to reach. The under-desk CPU holder has a 10.09" (485 mm) long track with an easy-glide sliding mechanism that allows the CPU to move sideways for enhanced accessibility.
The heavy-duty computer tower mount securely holds your PC case, with a weight capacity of up to 66 lb. (30 kg).
Product Description | StarTech.com Under Desk CPU Mount - Adjustable - Heavy-Duty Computer Tower Mount - 360° Swivel - Computer Mounting Bracket (CPUMNTUD) - system unit holder | Product Type | System unit holder | Placing / Mounting | Under-desk mountable | Package Content | Mounting plate, mounting screws, stoppers, stopper screws, foam sheet | Colour | Black | Product Material | Plastic, steel | Dimensions (WxDxH) | 25.3 cm x 21.3 cm x 66.5 cm | Weight | 5 kg | Features | Width adjustable, 360 degree swivel capability, adjustable height | Manufacturer Warranty | 2-year warranty |
General | |
Width | 25.3 cm |
Depth | 21.3 cm |
Height | 66.5 cm |
Weight | 5 kg |
Shipping Dimensions (WxDxH) / Weight | 5.4 kg |
Inner Dimensions | 25.3 cm x 55.7 cm |
Colour | Black |
Miscellaneous | |
Weight Limit | 30 kg |
Manufacturer Warranty | |
Service & Support | Limited warranty: - 2 years |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
