StarTech.com Under Desk CPU Mount
£93.46
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Save space by mounting your PC case under your desk, off the floor
  • Fits most CPU towers, with an adjustable frame (4.84” to 9.96” width and 14” to 21.9” height)
  • Heavy-duty CPU mount securely holds up to 66 lb. (30 kg)
  • Accessory Type: Mount
  • Stock Status: In Stock
Product codes
Maximize your workspace. This under-desk CPU mount frees up floor and desk space, and gives you easy access to your computer tower.
The under-desk CPU holder provides an easy way to mount your computer under any desk or flat surface. It helps keep your work space neat and organized, by mounting your computer case off the desktop or floor, away from dust and dirt. The under-desk PC mount is ideal for mounting your CPU under a standing or sit-stand desk, moving the CPU up and down along with the desktop as needed.
The heavy-duty CPU holder has an adjustable frame that supports a variety of PC cases, ranging in width from 4.84" to 9.96" (123 mm to 253 mm) and height from 14" to 21.9" (357 mm to 557 mm).
Offering a full 360-degree swivel, the under-desk PC mount provides easy access to your computer case, front and back, ensuring ports and cables are easy to reach. The under-desk CPU holder has a 10.09" (485 mm) long track with an easy-glide sliding mechanism that allows the CPU to move sideways for enhanced accessibility.
The heavy-duty computer tower mount securely holds your PC case, with a weight capacity of up to 66 lb. (30 kg).
Product Description StarTech.com Under Desk CPU Mount - Adjustable - Heavy-Duty - 360° Swivel system unit holder
Product Type System unit holder
Placing / Mounting Under-desk mountable
Package Content Mounting plate, mounting screws, stoppers, stopper screws, foam sheet
Colour Black
Product Material Plastic, steel
Dimensions (WxDxH) 25.3 cm x 21.3 cm x 66.5 cm
Weight 5 kg
Features Width adjustable, 360 degree swivel capability, adjustable height
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Under Des...
£93.46
