StarTech.com Under Desk Keyboard Tray
£60.72
Delivery:
Standard: 1-3 working days
  • Stock Status: In Stock
Product codes
Work in greater comfort with this easily adjustable ergonomic keyboard tray. This under-desk keyboard tray adds comfort to your work day, by easing the strain on your wrists and arms. It also frees up valuable desk space.
The spacious design of the keyboard tray, 26.4" (670 mm) wide x 10" (255 mm) depth, gives you ample room for your keyboard and mouse. Its quality construction, with a weight capacity of 4.4 lb. (2 kg), provides a stable platform that doesn't shake when you're typing.
The ergonomic design of this adjustable keyboard tray, including a built-in wrist rest, provides a wide range of movement to reduce discomfort and work-related injuries. It lets you adjust your position for comfortable arm and shoulder postures while typing, helping you be more productive throughout your work day.
Easily adjust your keyboard tray down or up, with a height adjustment range of up to 6.7" (170 mm). You can slide the keyboard tray in or out from your desk to find your ideal position. Turn the knob at the side to tilt the keyboard tray +15° / -15° for added comfort. You can even adjust your keyboard tray to the left or right, with +20° / -20° swivel.
The under-desk keyboard tray clears space on your desktop. The track-mounted design lets you slide it under your desk when not in use, with an extension range of up to 12.6" (320 mm).
Product Description StarTech.com Under-Desk Keyboard Tray - Adjustable - keyboard drawer
Product Type Keyboard drawer
Package Content Tray, mounting arm, 4 mounting screws, sliding rail, 4 rail screws, 4 tray screws, 4 screw covers, 2 rubber pads
Placing / Mounting Under-desk mountable
Product Material Plastic, steel
Dimensions (WxDxH) 78.2 cm x 67 cm x 21.5 cm
Weight 5 kg
Colour Black
Designed For P/N: ARMBARDUO, ARMBARDUOV, ARMBARTRIO2, ARMCBCL, ARMDUAL, ARMDUAL30, ARMDUALV, ARMPIVOT, ARMPIVOTB, ARMPIVOTE, ARMPIVOTHD, ARMPIVOTV2, ARMPIVSTND, ARMSLIM, ARMSLIMDUO, ARMTRIO, ARMUNONB, LTRISERP, MONSTADJD, MONSTADJDL
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Under Des...
£60.72
