StarTech.com Universal Laptop USB Docking Station with VGA Au...
StarTech.com Universal Laptop USB Docking Station with VGA Audio Ethernet
Product codes
4-in-1 Laptop docking station with VGA, Ethernet, dual audio and 4 port USB 2.0 connections. The USBVGADOCK2 is a combination USB VGA adapter and 4-in-1 docking station that converts a single USB 2.0 port into multiple connection ports, including: a VGA port, 10/100 RJ45 network connection, dual (3.5mm phono) audio ports and four additional USB 2.0 ports.
Compatible with a broad range of operating systems, including Microsoft Windows 7, the USB VGA adapter/docking station supports 1600x1200 (32-bit) display resolutions for connected VGA monitors and saves the time and hassle of having to disconnect devices like speakers and USB peripherals (scanners, printers, webcams etc.) in order to re-connect them to another computer. Using this convenient docking station makes it as simple as creating the single USB 2.0 host connection in order to access the connected peripherals.
Product Description StarTech.com Universal Laptop USB Docking Station w/VGA Audio Ethernet - docking station
Product Type Docking station
Docking Interface USB
Dimensions (WxDxH) 20.3 cm 1.9 cm
Colour Black
Networking Fast Ethernet
Power Power adapter - external
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Universal...
