StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4...
StarTech.com Universal USB 3.0 4K Laptop Docking Station w/ 4K DisplayPort
£147.61
Delivery:
Standard: 1-3 working days
Key features
  • Connect dual monitors (HDMI and 4K DP) to your Mac or Windows laptop
  • Achieve a higher resolution with up to 3840x2160p on a single display
  • Maximize your display capabilities with dual displays at 2048x1152p resolutions
  • Stock Status: In Stock
Product codes
Create a 4K Ultra HD or dual-monitor workstation through USB 3.0, even if your laptop doesn't natively support high-resolution output. The USB 3.0 4K Laptop Docking Station lets you create a high-resolution, 4K Ultra HD workstation in your office or at home. Now, you can discover leading-edge display technology, desktop convenience, and fast device charging by adding 4K DisplayPort, DP & HDMI dual video, USB quick-charge port, and several other vital connections to your laptop.
It's the perfect accessory for laptops and Ultrabooks, as well as your Microsoft Surface Pro 4, Surface Pro 3, Surface 3, Surface Pro 2 or Surface Book.
Deliver brilliant text and image quality, and an exciting visual experience with one of the first docking stations to support 4Kx2K (3840x2160p - 30Hz) resolution. Now, you can take advantage of the latest Ultra High Definition (UHD) displays, or prepare your workspace for the future popularity of 4K touch screens, displays, and video sources, which offer 4x as many pixels as full high-definition (1920x1080p).
Native 4K videos, applications, and graphics look crystal-clear and sharp with vivid realism, documents are crisp, and colors appear rich and more accurate. Easily add 4K capabilities to your Windows or Mac laptop, when connected to a single display via the dock DP video output and a DisplayPort-enabled 4K display. For extra display flexibility, pair the docking station with the DisplayPort to HDMI 4K Video Converter (SKU: DP2HD4KS - sold separately) to add support for a 4K HDMI-based display.
Work faster, and more efficiently! With dual monitor support (4K output not supported in dual monitor configuration), you can design an immersive, multi-display desktop proven to streamline work and save time. Be up-and-running in seconds with no headaches, simply connect DP and HDMI-enabled displays to the integrated monitor outputs and you're done.
A single USB 3.0 connection means docking your laptop (e.g. Lenovo ThinkPad, HP / Dell Ultrabook, MacBook Pro, MacBook Air) is hassle-free, too. Devices remain constantly connected, letting you overcome laptop port limitations while also eliminating the aggravation of continually reconnecting peripherals. You can even tuck the dock neatly under your laptop, to create a full-sized workstation that's organized and clutter-free. The dock is perfect for hoteling in shared workspaces, or for hot desks.
Fast-charge your tablet or smartphone, with or without a laptop connected to the dock! USB charging is fast, convenient, and easily accessible, through a side-facing, always-on USB fast-charge port that combines data throughput with support for USB Battery Charging Specification 1.2. You can create a dynamic shared workspace and get work done efficiently, while simultaneously adding charge and sync flexibility to a mobile device.
Now, you can enjoy true multitasking capability by rapid-charging your mobile device, fused with the performance and convenience of a full-sized 4K workstation. Plus, an integrated 4-port USB 3.0 hub-controller with support for UASP-enhanced performance offers faster data transfer rates, resulting in less waiting, and more productivity from your attached peripherals such as USB 3.0 external hard drives.
Product Description StarTech.com USB 3.0 Docking Station Dual Monitor with HDMI & 4K DisplayPort - 4x USB-A, Ethernet - USB Type A Universal Laptop Dock - docking station - HDMI, DP
Product Type Docking station
Docking Interface USB
Video Interfaces HDMI, DP
Dimensions (WxDxH) 7.8 cm x 22.6 cm x 3.1 cm
Weight 274 g
Colour Black
Networking Gigabit Ethernet
Power Power adapter AC 100/230 V
Designed For P/N: ARMBARDUO, ARMDUAL, ARMDUAL30, ARMSLIMDUO
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com Universal...
£147.61
