StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/...
StarTech.com Universal USB 3.0 Laptop Mini Docking Station w/ HDMI or VGA Gigabit Ethernet USB 3.0
£96.25
More than 50 In Stock
Delivery:
Standard: 1-3 working days
Key features
  • HDMI or VGA video output, USB 3.0 hub port, and GbE through just a single USB 3.0 connection
  • Compact and lightweight - multiple connection options in a travel-friendly casing designed for maximum portability
  • Built-in USB 3.0 cable, which can be tucked away neatly while not in use
  • USB bus-powered - No external power adapter required
  • Hassle-free setup - Latest drivers are automatically downloaded in Windows systems when an active network connection is present
  • Gigabit Ethernet RJ45 port - IEEE 802.3, 802.3u and 802.3ab (10BASE-T, 100BASE-TX, and 1000BASE-T) compatible
Product codes
Create a mobile workstation using your Ultrabook or laptop USB 3.0 port via this portable USB 3.0 mini dock. The USB3SMDOCKHV USB 3.0 Laptop Mini Docking Station lets you transform your Ultrabook or laptop into a mobile workstation, by adding HDMI or VGA video output, a USB 3.0 hub port, and a Gigabit Ethernet RJ45 port, all through a single USB 3.0 host connection - a travel-friendly solution that can help you overcome the connection port limitations of modern mobile computers.
Now, you can avoid the nuisance of carrying multiple adapters. By consolidating four essential connection ports into one convenient device, the USB3SMDOCKHV delivers the perfect laptop accessory. The mini docking station features a lightweight, compact design that fits nicely into your travel bag and also features an integrated host connection cable that tucks neatly into the docking stations casing.
A versatile solution for connecting an additional display to your laptop, the mini dock offers HDMI video output with audio, or VGA video output, providing two popular interfaces for connecting a television, projector, or monitor as a second display, with support for resolutions up to 2048x1152 (QWXGA). Leveraging the high-bandwidth (5 Gbps) USB 3.0 interface to deliver flexible video output, a USB 3.0 hub port, and Gigabit Ethernet, you can quickly set up a multi-functional workstation while on the run, without sacrificing one of your laptop USB ports.
Setup is seamless and hassle-free; the mini docking station will automatically download the latest driver when connected to a Windows system with an active network connection.
Product Description StarTech.com USB 3.0 to HDMI or VGA Adapter Dock - USB 3.0 Mini Docking Station w/ USB, GbE Ports - Portable Universal Laptop Travel Hub (USB3SMDOCKHV) - docking station - USB - HDMI - GigE
Product Type Docking station
Docking Interface USB
Video Interfaces HDMI
Dimensions (WxDxH) 5.5 cm x 12.5 cm x 1.7 cm
Weight 100 g
Colour Black
Networking Gigabit Ethernet
Power Power Provided
Designed For P/N: ARMPIVOT, ARMPIVOTE, ARMPIVSTND, ARMSLIM, ARMUNONB
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£96.25
