StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 80...
StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g  1T1R
£9.00
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with 802.11b/g/n Wi-Fi networks and a small form factor, delivers a versatile, portable wireless networking solution
  • Support for the latest security protocols and easy to use Wi-Fi Protected Setup (WPS) ensures a safe and efficient wireless experience anywhere you go
  • Backed by a StarTech.com 2-year warranty and free lifetime technical support
Product codes
Add High Speed Wireless N Connectivity to a Desktop or Laptop Computer through USB. The USB150WN1X1 USB 802.11N Mini Wireless Network Adapter allows almost any USB-enabled desktop, laptop or netbook computer system to connect to 'n', 'g' or 'b' wireless networks. Using a 1T1R (1 Transmitter/1 Receiver) design over the 2.4GHz frequency in an extremely compact form factor, the USB adapter is capable of reaching up to 150Mbps over an 802.11n network while taking up minimal space.
Backward compatible with 802.11b/g networks (11/54Mbps), this adapter is a versatile wireless networking solution.
Product Description StarTech.com USB 150Mbps Mini Wireless N Network Adapter 802.11n 1T1R - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Dimensions (WxDxH) 1.9 cm x 3.5 cm x 0.6 cm
Weight 2 g
Data Link Protocol 802.11b/g/n
Data Transfer Rate 150 Mbps
Frequency Band 2.4 GHz
Processor RTL8188CUS - Realtek Semiconductor
Compliant Standards IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
System Requirements Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Linux 2.6, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 10 (32/64 bits)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 150Mb...
£9.00
