StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 80...
StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R USB WiFi Adapter - White
£12.60
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Wired / Wireless: Wireless
  • Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
  • Form Factor: External
  • Compatibility: Mac, PC
  • Type: Network adapter
Product codes
Add high-speed Wireless-N connectivity to a desktop or laptop system through USB. The USB150WN1X1W USB Wireless Network Adapter lets you add high-speed Wireless-N connectivity to a desktop or laptop system through USB.
Using a 1T1R (1 Transmitter/1 Receiver) design over the 2.4GHz frequency, the USB WiFi adapter is capable of data transfer rates up to 150Mbps over an 802.11n network. The adapter uses a small form factor design that makes it conveniently portable and unobtrusive, when connected to a computer - it can even be left connected your laptop when in a carrying bag, without worry of damaging the adapter or the host port.
Backward compatible with 802.11b/g networks (11/54Mbps), this USB wireless adapter is a versatile wireless networking solution, offering support for security options such as WEP, WPA or WPA2, as well as wireless Quality of Service (QoS) support and quick device connection through Wireless Protected Setup (WPS).
Product Description StarTech.com USB 150Mbps Mini Wireless N Network Adapter - 802.11n/g 1T1R USB WiFi Adapter - White USB Wireless Adapter - Wireless NIC (USB150WN1X1W) - network adapter
Device Type Network adapter
Form Factor External
Interface (Bus) Type USB 2.0
Dimensions (WxDxH) 1.5 cm x 1.9 cm x 0.7 cm
Weight 9 g
Data Link Protocol 802.11b/g/n
Data Transfer Rate 150 Mbps
Frequency Band 2.4 GHz
Compliant Standards IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Colour White
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Apple MacOS X 10.5 - 10.14, Linux 2.6.x - 3.5, Linux 4.4.x - 4.11.x LTS versions only
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 150Mb...
£12.60
