StarTech.com USB 3.0 Data Transfer Cable
£33.03
More than 50 in stock
Delivery:
Standard: 1-3 working days
Product codes
Quickly and easily transfer all of your Windows or Mac files to your new computer. Here's an easy way to transfer files from your old computer to your new one. This data transfer cable lets you move files quickly over USB 3.0, and works with both Mac and Windows.
The transfer cable saves you time and effort when you're upgrading to a new computer. You can transfer your files and settings quickly over USB 3.0, also known as USB 3.1 Gen 1, with file transfer speeds up to 5 Gbps. Plus, there are no additional drivers to install when connecting your computers, because the necessary software is stored on the cable.
The data transfer cable supports a wide range of operating systems, working with Windows and Mac. The USB 3.0 transfer cable lets you transfer files between two computers including Windows to Windows, Windows to Mac, Mac to Windows, and even Mac to Mac.
The data transfer cable is compatible with Windows Easy Transfer software for migrating to newer versions of Windows, up to Windows 8. Plus, the built-in PCLinq software also allows file transfers in any direction between compatible operating systems, including Windows 10.
The USB3LINK data transfer cable comes in a convenient 2 m (6 ft.) length.
StarTech.com USB 3.0 Data Transfer Cable for Windows & Mac - Supports OS X - direct connect adapter
Direct connect adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
USB 3.0
Length
1.85 m
77 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
PL-27A1 - Prolific
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Vista / 7 / 8 / 8.1, Windows 10 (32/64 bits), Apple MacOS X 10.7.5 - 10.10
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 D...
£33.03
