StarTech.com USB 3.0 Dual 3.5in SATA III Hard Drive RAID Encl...
StarTech.com USB 3.0 Dual 3.5in SATA III Hard Drive RAID Enclosure with Fast Charge USB Hub & UASP
£107.61
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Save time, with file transfers faster than traditional USB 3.0 when used with a UASP-supported host
  • Charge your iPad and other mobile device faster than standard USB 3.0, with fast charge port
  • Preserve system resources using hardware-based RAID instead of software
  • Stock Status: In Stock
Product codes
Connect two 3.5" SATA III hard drives to your computer through USB 3.0 with UASP in a RAID array, and charge or connect USB devices with the built-in 2-port USB 3.0 fast charge hub. The S352BU33HR 2-Bay RAID Enclosure lets you build an external RAID array using two 3.5" SATA hard drives, and add it to your computer through USB 3.0.
For optimal performance from your SATA III drives, the external RAID enclosure supports a UASP-enabled USB 3.0 host connection, which performs up to 70% faster than conventional USB 3.0 when paired with a UASP compatible host controller.
The RAID enclosure also lets you connect additional USB 3.0 devices to your computer, through an integrated 2-port USB 3.0 hub conveniently mounted on the front of the enclosure. The easy-to-reach hub also has fast charging capabilities, so you can charge your iPad, smartphone or other mobile devices as quickly as you would through a direct wall outlet connection.
To help maintain safe operating temperatures for your hard drives, the 2-drive enclosure features a built-in cooling fan to ensure proper air circulation and prevent your SATA drives from over-heating.
The enclosure features an integrated hardware RAID controller, which gives you the options you need to set up the array that best suits your storage application, including JBOD, Spanning, RAID 0, and RAID 1.
To ensure compatibility with your computer system, theS352BU33HR supports all of the leading operating systems.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Product Description StarTech.com Dual 3.5" SATA HDD RAID Enclosure w/ USB Hub & UASP - hard drive array
Device Type Hard drive array
Colour Black
Max Supported Capacity 6 TB
Interface USB 3.0, SATA 6Gb/s
Installed Devices / Modules Qty 0 (installed) / 2 (max)
Supported Drives SATA-600
Built-in Devices Led panel
Storage Controller RAID (SATA 6Gb/s) - RAID 0, 1, JBOD, BIG
OS Required Linux, Microsoft Windows 2000, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Apple MacOS X Lion 10.7, Apple MacOS X 10.8, Apple MacOS X 10.9, Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits)
Power AC 120/230 V - 50 - 60 Hz
Dimensions (WxDxH) 11.55 cm x 18.2 cm x 9.5 cm
Weight 741 g
Designed For P/N: PEXUSB3S3GE, SVA12M5NA, TB2DOCK4K2DP, TB3DK2DHV, TB3DK2DHVUE, TB3DK2DPPD, TB3DK2DPPDUE, TB3DK2DPW, TB3DK2DPWUE, TB3DKDPMAW, TB3DKDPMAWUE, USB3DOCKHDPC, USB3VDOCK4DP
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 D...
£107.61
