StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive...
StarTech.com USB 3.0/eSATA Dual 3.5" SATA III Hard Drive External RAID Enclosure w/ UASP - Black
£74.98
10 left in stock
Delivery:
Standard: 1-3 working days
Key features
  • Versatile connectivity options, through either USB or eSATA
  • Time-saving file transfers, up to 70% faster than traditional USB 3.0 when used with a UASP-supported host
  • Achieve greater drive capacity or secure data redundancy with multiple RAID modes
  • Maximize performance, with file transfer speeds up to 6 Gbps using SATA III
  • Stock Status: Clearance
Product codes
The S3520BU33ER 2-Bay RAID enclosure offers a high-performance external storage solution, enabling you to build a secure RAID array with two 3.5" SATA hard drives, with the option to connect it to your computer through either an available USB 3.0 or eSATA port.
For fast data transfers and efficient performance from your SATA III drives, the RAID enclosure supports full SATA III transfer speeds, as well as full USB 3.0 transfer speeds. When connected through USB, the enclosure supports UASP, which offers performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller.
With support for JBOD, Spanning, RAID 0, and RAID 1, the enclosure offers several options that enable you to customize your drive arrangement based on your storage requirements. To maximize both durability and reliability, the external RAID enclosure features high-quality aluminum construction with a built-in fan that helps improve ventilation and maintain a better operating environment for your drives.
Product Description StarTech.com USB 3 eSATA Dual 3.5" SATA III HDD RAID Enclosure UASP - hard drive array
Device Type Hard drive array
Colour Black
Max Supported Capacity 4 TB
Interface USB 3.0, SATA 6Gb/s
Installed Devices / Modules Qty 0 (installed) / 2 (max)
Supported Drives SATA-600
Storage Controller RAID (SATA 6Gb/s) - RAID 0, 1, JBOD, BIG
Hard Drive No HDD
OS Required Apple MacOS, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits)
Power AC 120/230 V - 50 - 60 Hz
Dimensions (WxDxH) 11.55 cm x 18.05 cm x 8.5 cm
Weight 980 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0/e...
£74.98
