StarTech.com USB 3.0 Extender over Fiber
£1,330.63
Delivery:
Standard: 1-3 working days
Key features
  • USB 3.0 OVER FIBER EXTENDER: Extend and connect two USB 3.2 Gen 1 (5Gbps) devices up to 1150 ft (350 m) away over an OM3 multimode LC to LC fiber cable - Built with durable aluminum construction for high wear and tear environments
  • CONNECT REMOTE USB DEVICES: Works as a two port USB hub at remote location on a campus or between buildings for connecting USB cameras, POS devices, printers, scanners, plotters, keyboard/mouse, storage - Connection and power LEDs for activity and status
  • RELIABLE DATA TRANSFER: Unlike copper cable, optical fiber is not affected by Electromagnetic Interference (EMI), ensuring that the USB signal is delivered from transmitter to receiver without signal degradation or interference over long distances
  • ACTIVE USB EXTENDER: The secure locking power adapter (included) for the remote receiver unit provides 5V (0.9A) to each port - the local extender (transmitter) is USB bus powered by the host computer - Includes secure screw locking USB cable
  • EASY SETUP: The Point-to-Point USB fiber extender features driverless setup and is compatible with major operating systems incl. Windows, macOS, Linux - 2x 10G MMF SFP+ modules included - Compatible with USB 3.0/2.0/1.1 - Not compatible w/ LAN equipment
Product codes
With this high-performance USB over Multimode Fiber Extender you can extend 5Gbps USB 3.2 Gen 1 signals over an OM3 LC to LC fiber cable with a range of up to 1150ft (350m).
Product Description StarTech.com 2-Port USB 3.0 Extender over OM3 Multimode Fiber, LC/LC, 2x 5Gbps USB-A Hub, 350m (1150ft) Range, Durable USB Fiber Optic Extender, Incl. 2x 10G MMF SFP+ modules - Optical USB Extender (F35023-USB-EXTENDER) - USB extender - USB 3.0 - TAA Compliant
Device Type USB extender
Ports Qty 2
Form Factor External
Data Transfer Rate 5 Gbps
Data Link Protocol USB 3.0
Transmission Medium CAT 5e
Max Transfer Distance 350 m
Power AC 100-240 V
System Requirements Apple MacOS, Linux, Microsoft Windows
Dimensions (WxDxH) 9.3 cm x 5.7 cm x 2.8 cm
Weight 271 g
TAA Compliant Yes
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
£1,330.63
