StarTech.com USB 3.0 Front Panel 4 Port Hub – 3.5in or 5.25in...
StarTech.com USB 3.0 Front Panel 4 Port Hub – 3.5in or 5.25in Bay
£42.03
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by a StarTech.com 2-year warranty and free lifetime technical support
  • Connect up to four USB 3.0/2.0/1.x devices simultaneously, through your computers front 3.5" bay
  • SuperSpeed USB 3.0 supports up to 5 Gbps of bandwidth and up to 900mA of power per port to support faster and more powerful devices
  • Ports: 4
  • Stock Status: In Stock
Product codes
The 35BAYUSB3S4 3.5-inch Front Bay to 4-Port USB 3.0 Panel Hub turns any available 3.5-inch computer case front bay into a 4-Port USB 3.0 hub.
Using only a single USB connection, this front panel hub adds four easily accessible USB ports to the front of your computer case through a 3.5-inch bay, or through a 5.25-inch bay using the optional Front Bay Bracket Adapter (BRACKETFDBK) accessory. Each of the added ports is compliant with the USB 3.0 standard which supports up to 5 Gbps of bandwidth (10x faster than the USB 2.0 standard) and up to 900mA of power.
Accessorize with the PEXUSB3S11 PCI Express card to provide an internal USB 3.0 port, so as to keep the external ports free for external devices. Backed by a StarTech.com 2-year warranty and free lifetime technical support.
The StarTech.com Advantage
Four front accessible USB type-A ports
Fits into any 3.5" computer case front bay
SuperSpeed USB 3.0 compliant, supporting data transfer rates up to 5 Gbps
Backward compatible with USB 2.0 and USB 1.0/1.1 specifications and devices
Provides up to 900mA of power per port
USB Link LED indicator for each port
Applications
Expand your system's USB 3.0 capabilities with additional ports for connecting high speed external storage devices
Add easier to access USB ports to the front of a computer system instead of the rear
Make use of an internal USB port and unused 3.5" front bay to increase the system's expandability
Product Description StarTech.com USB 3.0 Front Panel 4 Port Hub - 3.5 5.25in Bay - hub - 4 ports - plug-in module
Device Type Hub - 4 ports
Enclosure Type Plug-in module
Subtype USB
Ports 4 x SuperSpeed USB 3.0
Dimensions (WxDxH) 10 cm x 12 cm x 2.5 cm
Weight 160 g
Colour Black
System Requirements Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 F...
£42.03
