StarTech.com USB 3.0 HDMI Capture Device
Key features
  • High-performance capture at 1080p 60 fps
  • H.264 encoding for wide device compatibility
Product codes
Record HDMI video and audio, with the option for an additional 3.5mm embedded audio source, to your computer at 1080p 60fps resolution. This capture device turns your USB 3.0 computer into a digital video recorder for high quality HDMI video, leveraging USB 3.0 transfer speed to capture raw 1080p video at 60 frames per second. The capture device records video and audio from your HDMI source device and also includes a separate 3.5 mm audio input jack, which enables you to record the video's accompanying analog audio output, or add your own independent audio source for voice over commentary.
Record video at 60 FPS ensuring every frame of content is saved, unlike 30-frame-per-second capture devices that only catch half the action. 1080p60 exactly matches the output of most computer video cards, which is great for recording the output from your PC, server, or POS station, when creating software training and tutorial videos. Plus, with support for 1080p video, you can ensure crystal-clear capture quality at high-definition resolution, and create high-quality video to distribute internally throughout your business or distribution over the Internet.
This USB capture card is capable of capturing raw video, making it compatible with Microsoft DirectShow. With raw video capture you can record video using your preferred third party DirectShow software such as Open Broadcaster Software (OBS).
The software that's included with the capture card encodes in H.264 -- the most widely adopted video codec in the world. H.264 encoding capability ensures the video files you save will be compatible with almost any video player such as the media software on your PC, Mac, iOS and Android devices, with no editing or converting needed. H.264 is also widely supported by most software titles, including Adobe Premiere and Windows Media Encoder.
Product Description StarTech.com USB 3.0 Capture Device for High-Performance HDMI Video - 1080p 60fps - video capture adapter - USB 3.0
Device Type Video capture adapter
Interface Type USB 3.0
Dimensions (WxDxH) 5.8 cm x 9.2 cm x 2.8 cm
Weight 88 g
Video Input SuperSpeed USB 3.0, HDMI input
Video Modes 1080/60p
Digital Video Format MPEG-4, H.264
Digital Video Capture Speed 60 frames per second
Audio Input Support Standard
OS Required Microsoft Windows 7 / 8 / 8.1 / 10
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
