StarTech.com USB 3.0 Multi-Card Reader
£33.38
21 in stock
Delivery:
Standard: 1-3 working days
Key features
  • USB 3.0 (5 Gbps) multi-card reader transfers video, images and files at ultra-fast speeds
  • Supports UHS-II with transfer speeds of up to 312 MB/s
  • Multi-card reading and writing for most standard cards, including: SecureDigital, Micro SD, Compact Flash, Memory Stick and more
  • Supported Formats: CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick Duo + 12 more
  • Interface: USB 3.0
  • Stock Status: In Stock
Product codes
Turn a 3.5" internal bay on your computer into a fast and versatile memory card reader - for SD, Micro SD, CF, Memory Stick and more. Now, you can transfer large files like photos and 4K video, back up files or offload data, to and from your memory cards, at speeds like never before. This USB 3.0 internal multi-card reader supports UHS-II to greatly enhance your file transfer rates. The card reader supports High Capacity/eXtended Capacity cards and most standard memory cards, including SecureDigital, Compact Flash, Memory Stick and micro SD cards. It also enables concurrent downloads. Fast speed and wide compatibility make this multi-card reader an ideal solution for photo kiosks or photo labs, and desktop computers.
The card reader is USB powered so there's no external power or battery required. Front USB access lets you connect USB devices easily.
With support of UHS-II cards, the multi-card reader lets you transfer large files to and from your memory cards at speeds of up to 312 Mbps, saving you time on data offloads of 4K, full HD and 3D videos.
Using a USB 3.0 connection, also known as USB 3.1 Gen 1, the card reader supports fast file transfer speeds of up to 5 Gbps, enabling you to leverage the increased capabilities of new, higher performing memory cards.
Save time with concurrent downloads. This 5-slot multi-card reader design allows you to access up to four memory cards simultaneously for fast and easy file transfers.
The USB 3.0 multi-card reader works with most standard memory cards, including: Secure Digital (Standard Card, HC card, XC card, MMC, Mini SD with adapter); Micro SD (Standard card, HC card, XC card); Compact Flash (CF I or II, CF 6.0); Memory Stick (Standard, Pro, Duo, Pro Duo, Pro-HG, XC, Micro MS with adapter).
Product Description StarTech.com USB 3.0 Internal Multi-Card Reader w/ UHS-II -SD/MicroSD/MS/CF - card reader - USB 3.0
Product Type Card reader - internal
Supported Memory Cards CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, microSD, SDHC Memory Card, Memory Stick Micro (M2), microSDHC, SDXC Memory Card, Memory Stick XC, Memory Stick PRO-HG
Host Interface USB 3.0
Required Bay 3.5" internal
Colour Black
Features LED indicator
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 M...
£33.38
