StarTech.com USB 3.0 Multi Media Flash Memory Card Reader
£24.75
Delivery:
Standard: 1-3 working days
Key features
  • Backed by a StarTech.com 2-year warranty and free lifetime technical support
  • SuperSpeed USB 3.0 interface for high speed data transfers to support the latest large capacity and fastest flash memory cards
  • Use the most popular flash memory card formats from a single portable reader
  • Supported Formats: CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick Duo + 13 more
  • Interface: USB 3.0
  • Stock Status: In Stock
Product codes
Add the Ability to Use Multiple Types of Flash Memory Cards, Including CompactFlash?, SecureDigital? and MemoryStick? Cards. The FCREADHCU3 USB 3.0 Card Reader enables easy read/write access to a variety of popular flash memory card formats/types (CompactFlash?, Secure Digital?, Memory Stick?) in a single unit, over a high speed USB 3.0 connection. Using a connection over USB 3.0, which is up to 10 times faster than the USB 2.0 standard, makes transferring large data files much quicker; it (USB 3.0) is still backward compatible with USB 2.0 however, ensuring compatibility with older systems. This compact and lightweight external card reader offers a portable, convenient solution for accessing many different types of Flash Memory/Media cards and is easy to use, with no driver or software installation required.
Product Description StarTech.com USB 3.0 Multi Media Flash Memory Card Reader - Card reader (Multi-Format) - USB 3.0 - FCREADHCU3 - card reader - USB 3.0
Product Type Card reader - external
Supported Memory Cards CompactFlash Card type I, CompactFlash Card type II, Memory Stick, Memory Stick PRO, MultiMediaCard, SD Memory Card, Memory Stick Duo, Memory Stick PRO Duo, miniSD, RS-MMC, microSD, SDHC Memory Card, miniSDHC, microSDHC, Memory Stick PRO-HG Duo, SDXC Memory Card, microSDXC
Host Interface USB 3.0
Colour Black
Features Power indicator
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 M...
£24.75
