StarTech.com USB 3.0 Network Adapter-Silver
£26.08
Delivery:
Product codes
Add a Gigabit Ethernet port to your MacBook, Chromebook or tablet. Gain fast, reliable network access for your MacBook, Chromebook or tablet, even if it doesn't have an Ethernet port. This USB 3.0 to Gigabit network adapter adds a single RJ45 Ethernet port to your computer through your USB 3.0 port. It installs instantly - with no driver required.
Engineered with a quality aluminum housing in a silver finish, the network adapter is the perfect companion for your MacBook, Chromebook or tablet. Compact and portable, this USB network adapter is the ideal laptop accessory. You don't have to carry a power adapter with you to use it, because it's powered directly from the host USB port.
Ideal for office or home use, the USB 3.0 network adapter supports full Gigabit bandwidth by harnessing the performance of USB 3.0 (5 Gbps). You can quickly access very large files over a Gigabit network, saving valuable time every day. The Realtek chipset gives you the assurance of reliable performance.
Get up and running quickly. Simply plug this Ethernet cable adapter into the USB port on your laptop and connect to your network. The network adapter chipset provides native driver support, so you don't have to worry about installing additional software.
Product Description StarTech.com USB 3.0 to Gigabit Network Adapter - Silver - Sleek Aluminum Design for MacBook, Chromebook or Tablet - Native Driver Support (USB31000SA) - network adapter - USB 3.0 - Gigabit Ethernet x 1
Device Type Network adapter
Form Factor External
Interface (Bus) Type SuperSpeed USB 3.0
Ports Gigabit Ethernet x 1
Dimensions (WxDxH) 2.5 cm x 6.5 cm x 1.7 cm
Weight 36 g
Cabling Type Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
Data Link Protocol 10Mb LAN, 100Mb LAN, GigE
Capacity Jumbo frame size: 9000
Processor Realtek Semiconductor RTL8153
Compliant Standards IEEE 802.3, IEEE 802.3u, IEEE 802.3i, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3az
Colour Silver
System Requirements Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2012, Microsoft Windows XP / Vista / 7 / 8 / 8.1 / 10, Microsoft Windows Server 2016, Linux Kernel 2.6.25 - 4.11.x LTS versions, Microsoft Windows Server 2019, Apple MacOS X 10.7 - 10.14
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 N...
£26.08
