StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD...
StarTech.com USB 3.0 SATA III Hard Drive Docking Station SSD / HDD with UASP
£41.34
20 in stock
Delivery:
Standard: 1-3 working days
  • Type: Storage controller
  • HD Size: 2.5", 3.5"
  • Stock Status: In Stock
Product codes
Dock your 2.5in or 3.5in SATA III SSDs/HDDs over USB 3.0 with UASP. The SDOCKU33BV UASP-enabled USB 3.0 docking station makes it easy for you to connect and swap 2.5in or 3.5in SATA III hard drives (HDD) and solid state drives (SSD) through an available USB port. The dock performs up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller to utilize the full potential of your SATA III hard drives.
With support for large capacity SATA I/II/III drives (tested up to 4TB), and 2.5in or 3.5in drives this HDD/SSD docking station is compatible with virtually any SATA drive, and greatly increases the storage/backup capabilities of your computer.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in IDE hard drive into a SATA hard drive dock.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
Product Description StarTech.com USB 3.0 to 2.5/3.5" SATA III HDD/SSD Docking Station with UASP - storage controller - SATA 6Gb/s - USB 3.0
Device Type Storage controller - external
Bus Type USB 3.0
Hard Drive Form Factor Compatibility 2.5", 3.5"
Features Power indicator
Interface SATA 6Gb/s
Data Transfer Rate 6 Gbit/s
Supported Devices Hard drive
Power AC 100/230 V
System Requirements Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Linux 2.6.31 or later, Windows 8 (32/64 bits)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 S...
£41.34
