StarTech.com USB 3.0 to 2.5/3.5" SATA HDD / SSD Duplicat...
£66.19
Delivery:
Standard: 1-3 working days
Key features
  • Quickly copy hard drives, with standalone sector by sector HDD/SSD duplication
  • Securely erase up to two drives simultaneously, with Single Pass HDD overwriting
  • Hassle-free access to drive data, with hot-swappable top slot-loading dock design that supports both 2.5in and 3.5in HDD/SSDs
  • Stock Status: In Stock
Product codes
Clone a 2.5in/3.5in SATA drive without a host computer connection, or dock the drives over USB 3.0 for easy access. The SATDOCK2REU3 USB 3.0 Standalone Duplicator and Eraser Dock lets you connect your 2.5in/3.5in SATA HDDs or SSDs through SuperSpeed USB 3.0, with the ability to swap drives in and out as needed. The dock also functions as a standalone drive duplicator and eraser - an efficient and versatile solution for external drive management.
Featuring standalone Sector by Sector hard drive duplication with built-in LED progress bar, and support for 2 drive single pass over writing the SATDOCK22EU3 is a user-friendly all-in-one solution for any application requiring hard drive duplication or erasing.
With support for SATA I/II/III, and large capacity drives (tested up to 4TB) this HDD/SSD docking station is compatible with virtually any SATA hard drive, and greatly increases the storage/backup capabilities of your computer.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in IDE hard drive into a SATA hard drive dock.
Product Description StarTech.com Dual Bay USB 3.0 Duplicator and Eraser Dock for 2.5" & 3.5" SATA SSD HDD - 1:1 Standalone Cloner & Wiper Docking Station (SATDOCK2REU3) - hard drive duplicator
Device Type Hard drive duplicator
Installed Devices / Modules Qty 0 (installed) / 2 (max)
Supported Drives SATA-300
Storage Controller SATA (SATA 3Gb/s)
Hard Drive No HDD
OS Required Linux, Apple MacOS X, Microsoft Windows Server 2008 R2, Microsoft Windows Server 2003 (32/64-bits), Microsoft Windows Vista / XP / 7 / 8, Microsoft Windows Vista / XP / 7 / 8 (64-bit versions)
Power AC 120/230 V
Dimensions (WxDxH) 10.3 cm x 12.8 cm x 6.2 cm
Weight 562 g
Designed For P/N: SVA12M5NA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
£66.19
