StarTech.com USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking S...
StarTech.com USB 3.0 to 4-Bay SATA 6Gbps Hard Drive Docking Station w/ UASP & Dual Fans
£174.30
10 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Save time, with file transfers up to 70% faster than traditional USB 3.0 when used with a UASP-supported host
  • Hassle-free operation with independent SATA controllers allowing for uninterrupted data transfers while hot-swapping the other drives
  • Helps to prevent premature drive failure, with built-in dual 40 mm fans that keep your drives running cool
  • Stock Status: In Stock
Product codes
Connect and swap four 2.5/3.5" SATA III (6 Gbps) drives through USB 3.0 with UASP. The SDOCK4U33 four-bay 2.5/3.5" SATA HDD / SSD docking station lets you dock and swap four drives from your desktop or laptop computer simultaneously, using a single USB port.
Get the most out of your SATA III (Gbps) solid state drives and hybrid drives with this UASP (USB Attached SCSI Protocol) enhanced hard drive docking station. With performance up to 70% faster than conventional USB 3.0 when paired with a UASP-enabled host controller, UASP ensures high performance by reducing bottleneck.
The hard drive dock features independently-powered SATA connectors for each individual drive, ensuring you can operate drives separately. This gives you the freedom to hot-swap one drive while transferring data to another, saving you time. Plus, the built-in fans keep your drives running cool, ensuring optimal performance and helps to prevent premature drive failure.
Extend the value of this hard drive docking station further with the addition of the SATA to IDE Hard Drive Adapter (SAT2IDEADP), allowing easy insertion of any 2.5 or 3.5in. IDE hard drive into a SATA hard drive dock.
To ensure compatibility with your computer system, the SDOCK4U33 supports all of the leading operating systems, including: Microsoft Windows (8/7/Vista/XP/Server 2008/Server 2003), Apple OSX (10.9/10.8/10.7/10.6), Linux, and Google Chrome OS.
UASP is supported in Windows 8, Mac OSX (10.8 or above), and Linux. In testing, UASP performs with a 70% faster read speed and 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing UASP also shows an 80% reduction in required processor resources.
Testing results were obtained using an Intel Ivy Bridge system, a UASP-enabled StarTech.com Enclosure, and a SATA III solid state drive.
Product Description StarTech.com 4 Bay USB 3.0 (5 Gbps) Hard Drive Docking Station w/ UASP for 2.5" & 3.5" SATA SSD HDD - Multiple External Hard Drive Cloner/ Copier Dock (SDOCK4U33) - storage enclosure
Device Type Storage enclosure
Colour Black
Installed Devices / Modules Qty 0 (installed) / 4 (max)
Supported Drives SATA-600
OS Required Linux, Apple MacOS X 10.6, Microsoft Windows Vista (32/64 bits), Microsoft Windows Server 2008 (32/64-bits), Microsoft Windows Server 2003 (32/64-bits), Google Chrome OS, Apple MacOS X Lion 10.7, Apple MacOS X 10.8, Apple MacOS X 10.9, Microsoft Windows XP / 7 / 8 / 8.1 (32/64 bits)
Power AC 120/230 V
Dimensions (WxDxH) 17.12 cm x 29.05 cm x 8.73 cm
Weight 1.028 kg
Designed For P/N: SVA12DN4NEUA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
£174.30
