StarTech.com USB 3.0 to DisplayPort External Video Card Multi...
StarTech.com USB 3.0 to DisplayPort External Video Card Multi Monitor Adapter – 2560x1600
Key features
  • SuperSpeed USB 3.0 to Displayport conversion delivers improved bandwidth, compared to a USB 2.0 connection, for smoother high-definition video content
  • The USB 3.0 DisplayPort adapter is USB-Powered device, making it easy to add additional graphical capability to your system, without opening the case or voiding system warranties or having to find an available wall power outlet
Product codes
Connect a DisplayPort-equipped display through USB 3.0, for an HD external multi-monitor solution. The USB32DPPRO USB 3.0 to DisplayPort Multi Monitor Adapter functions as an external DisplayPort video card, turning an available USB 3.0 port into a DisplayPort output, with support for high resolution 2560x1600 video, and 5.1 surround sound audio. The USB 3.0 DisplayPort adatper delivers a convenient, high-performance external video solution that makes it easy to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your DisplayPort-capable display, and can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
StarTech.com USB 3 to DisplayPort External Video Card Multi Monitor Adapter - external video adapter - DisplayLink DL-3500 - 64 MB - black
External video adapter
Bus Type
SuperSpeed USB 3.0
Graphics Engine
DisplayLink DL-3500
64 MB DDR2
Max Resolution
2560 x 1600
DisplayPort
2.64 cm x 8.12 cm x 1.12 cm
Enclosure Colour
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
