StarTech.com USB 3.0 to DVI / VGA External Video Card Multi M...
StarTech.com USB 3.0 to DVI / VGA External Video Card Multi Monitor Adapter – 2048x1152
£80.65
Delivery:
Standard: 1-3 working days
Key features
  • SuperSpeed USB 3.0 to DVI conversion provides added bandwidth, for smooth high-resolution video content
  • External USB-Powered device provides the simplest way to add additional graphics capability to your system, without opening the case or voiding system warranties
  • Stock Status: In Stock
Product codes
Connect a DVI display through SuperSpeed USB 3.0, for an accelerated external multi-monitor solution at resolutions up to 2048x1152. The USB32DVIPRO USB 3.0 to DVI Adapter turns an available USB 3.0 port into a DVI output, with high resolution 2048x1152 video support - a convenient external video solution that makes it easy to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0). Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter functions as an external graphics card to deliver smooth, high-resolution content to your DVI or VGA-capable display (DVI to VGA Adapter included). The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
Product Description StarTech.com USB 3.0 to DVI / VGA Adapter - 2048x1152 - External Video & Graphics Card - Dual Monitor Display Adapter Cable - Supports Mac & Windows (USB32DVIPRO) - external video adapter - DisplayLink DL-3100N - 512 MB - black
Device Type External video adapter
Bus Type SuperSpeed USB 3.0
Graphics Engine DisplayLink DL-3100N
Memory 512 MB DDR2
Max Resolution 2048 x 1152
Interfaces DVI-I (dual link) , VGA - with adapter
Dimensions (WxDxH) 4.4 cm x 7.8 cm x 1.6 cm
Enclosure Colour Black
Designed For P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
£80.65
