StarTech.com USB 3.0 to DVI External Video Card Multi Monitor...
StarTech.com USB 3.0 to DVI External Video Card Multi Monitor Adapter with 1-Port USB Hub  1920x1200
£57.93
42 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Keep a USB 3.0 port available on your Ultrabook or slim laptop, using the built-in USB 3.0 hub
  • Enjoy smooth, high resolution video content, using a high bandwidth USB 3.0 connection
  • Stock Status: In Stock
Product codes
Connect a DVI-equipped display through USB 3.0, while keeping the USB 3.0 port available. The USB32DVIEH USB 3.0 to DVI Adapter turns an available USB 3.0 port into a DVI output port with high resolution 1920x1200 video support. The adapter features a built-in 1-Port USB 3.0 hub, which offers a connection port in place of the USB port used for connecting the DVI adapter - an ideal workaround for Ultrabook or laptop users where only a limited number of USB ports are available.
The USB to DVI adapter functions as an external graphics card, providing a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0). The included DVI to VGA adapter also allows you to use this device with a VGA display.
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your DVI display / projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
Product Description StarTech.com USB 3.0 to DVI External Video Card Adapter with 1-Port USB Hub - external video adapter - T5-302 - 16 MB - black
Device Type External video adapter
Bus Type SuperSpeed USB 3.0
Graphics Engine MCT Trigger 5 T5-302
Memory 16 MB DDR2
Max Resolution 1920 x 1200
Interfaces DVI-I (dual link) , USB 3.0 , VGA - with adapter
Dimensions (WxDxH) 4.9 cm x 8.5 cm x 1.7 cm
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
£57.93
