StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable -...
StarTech.com USB 3.0 to eSATA HDD / SSD / ODD Adapter Cable - 3ft eSATA Hard Drive to USB 3.0 Cable
£27.51
38 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Compatible with USB 3.0/2.0/1.1
  • eSATA interface compliant with SATA revision 3 and other SATA revisions, with supported data transfer rates up to 6 Gbps
  • Supports hard drives (HDD), solid state drives (SSD) and optical disc drives (ODD)
  • 1x eSATA connector, 1x USB 3.0 connector with integrated 1 m (3.3 ft) cable
  • No driver or software installation required
  • Plug-and-Play and hot-swap compatible
  • Stock Status: In Stock
Product codes
Connect an eSATA storage device to a USB 3.0 port on your laptop or desktop. The USB3S2ESATA3 USB 3.0 to eSATA drive cable lets you connect any eSATA hard drive, solid state drive, or optical disc drive to your USB-enabled computer system - a great solution for computers that don't natively support eSATA, such as MacBook and Ultrabook computers.
To maximize performance and utilize the speed potential of your SATA 6 Gbps drives, the USB 3.0 to eSATA adapter is compatible with SATA revisions I/II/III and supports transfer speeds up to 5 Gbps through USB 3.0.
With support for Blu-ray/DVD/CD ATAPI / ODD drives and large capacity HDD / SSDs (tested up to 4TB) the USB to eSATA adapter cable is compatible with virtually any eSATA device, and can greatly increase the storage/backup capabilities of your computer.
The USB 3.0 to eSATA drive cable ensures a hassle-free connection with simple plug-and-play installation, plus the cable is the perfect length (1-meter, end-to-end) for easily accessing the rear panel USB ports on your computer.
Product Description StarTech.com USB 3.0 to eSATA Adapter Cable - storage controller - eSATA 6Gb/s - USB 3.0
Device Type Storage controller - external
Bus Type USB 3.0
Interface eSATA 6Gb/s
Data Transfer Rate 6 Gbit/s
Supported Devices Hard drive, solid state drive
Max Storage Devices Qty 1
Dimensions (WxDxH) 2.5 cm x 80 cm x 1 cm
Weight 137 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
£27.51
