StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Vi...
StarTech.com USB 3.0 to HDMI and DVI Dual Monitor External Video Card Adapter
£86.50
21 in stock
Delivery:
Standard: 1-3 working days
Key features
  • With two video output ports, the dual head design of the adapter offers a compact multi-monitor solution across both HDMI and DVI technology
  • SuperSpeed USB 3.0 to HDMI/DVI conversion delivers improved bandwidth compared to a USB 2.0 connection for smoother high-definition video content
  • The adapter is installed externally, through USB, which enables you to add graphics capability to your system without opening the case or voiding system warranties
  • Stock Status: In Stock
Product codes
The USB32HDDVII USB 3.0 to HDMI and DVI-I Dual Head Adapter turns an available USB 3.0 port into one DVI-I or VGA port (DVI to VGA adapter included) and one HDMI output, with support for high-definition 1080p and 1920x1200 video and 5.1 surround sound audio (from HDMI port only). The adapter delivers a convenient external video solution that makes it easy to add multi-monitor capability to a USB-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the USB video adapter functions as a convenient external graphics card that eliminates having to open the computer case for video card installation. The adapter delivers smooth, high-definition content to multiple displays and can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop onto a second or third monitor to double or triple your workspace and increase your productivity.
Product Description StarTech.com USB 3.0 to HDMI / DVI Adapter - 2048x1152 - External Video & Graphics Card - Dual Monitor Display Adapter Cable - Supports Mac & Windows (USB32HDDVII) - external video adapter - DisplayLink DL-3900 - 1 GB - black
Device Type External video adapter
Bus Type SuperSpeed USB 3.0
Graphics Engine DisplayLink DL-3900
Memory 1 GB
Max Resolution 2048 x 1152
Interfaces HDMI , DVI-I (dual link) , VGA - with adapter
Dimensions (WxDxH) 4.5 cm x 7.28 cm x 2 cm
Enclosure Colour Black
Designed For P/N: DVIDDMM10, DVIDDMM6, DVIDSMM10, DVIMM6, DVISPL1DD, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
£86.50
