StarTech.com USB 3.0 to HDMI External Multi Monitor Video Gra...
StarTech.com USB 3.0 to HDMI External Multi Monitor Video Graphics Adapter for Mac & PC
£63.10
26 in stock
Delivery:
Standard: 1-3 working days
Key features
  • USB 3.0 host connection provides maximum bandwidth for superior performance
  • Increase productivity by mirroring or extending your desktop onto another display
  • DisplayLink Plug-and-Display certified - automatic driver installation and updates
  • Stock Status: In Stock
Product codes
Connect an additional HDMI display to your Mac or PC with USB 3.0 technology capable of video playback at 1080p. The USB32HDPRO USB 3.0 to HDMI Adapter lets you add an HDMI display to your computer through a USB 3.0 port, providing a cost-effective and convenient way to expand the video capabilities of your Mac or PC computer system.
With USB 3.0 support, this external video adapter delivers the bandwidth needed for accelerated High-Definition video performance, capable of outputting video resolutions up to 1920x1200 / 1080p. Even if your current computer doesn't have a USB 3.0 port available, the USB32HDPRO is backward compatible with USB 2.0, so you'll be able to connect your HDMI monitor to your computer and be ready for when you upgrade to a USB 3.0-equipped system.
Add the screen space you need to simplify multitasking and maximize productivity, without even opening your computer case. Some computer systems, including MacBook and Ultrabook laptops and small form-factor desktops, are too compact to install an internal video card. A USB display adapter offers an easy workaround, performing as an external video card that only requires an available USB port to mirror or extend your desktop onto another display.
Installation has never been easier. When you connect this DisplayLink Plug and Display certified adapter to a web-enabled Windows 10, Windows 8 or Windows 7 computer, it automatically downloads and installs the most up-to-date drivers for you, so you won't have to manually download or install any software.
Product Description StarTech.com USB 3.0 to HDMI External Video Card Adapter - DisplayLink Certified - 1920x1200 - MultiMonitor Graphics Adapter - Supports Mac & Windows (USB32HDPRO) - external video adapter - black
Device Type External video adapter
Bus Type SuperSpeed USB 3.0
Interfaces HDMI , USB 3.0 (male connector)
Enclosure Colour Black
Designed For P/N: HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6, HDMM10, HDMM12, HDMM15, HDMM1MP, HDMM25, HDMM2M, HDMM2MP, HDMM3, HDMM3MP, HDMM50, HDMM50A, HDMM6, HDPMM50
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
£63.10
