StarTech.com USB 3.0 to SATA ODD Enclosure
£18.61
37 in stock
Delivery:
Standard: 3-5 working days
  • Type: Storage enclosure
  • Stock Status: In Stock
Product codes
Turn your Blu-ray or DVD ROM drive into a portable, external disk drive. This durable optical drive enclosure helps make your laptop, Ultrabook or tablet even more powerful by adding an external USB 3.0 Optical Disk Drive (ODD). Simply slide your slimline SATA Blu-ray, CD or DVD-ROM drive into this compact portable enclosure to add optical reading and writing support to your computer.
With USB 3.0 as the output interface, the drive enclosure supports up to 5Gbps transfer rate. Now you can access videos and other large files quickly to save valuable time while you're on the go.
With a durable, solid-aluminum housing, this top-quality external enclosure gives you the compact portability you need when you're on the move or in the field. Plus, the enclosure is USB-powered, so you won't have to carry a power adapter with you everywhere you go.
The optical drive enclosure is OS independent, so you can rest assured it's compatible with any operating system including Mac, Windows, Linux and Android.
It's also backward compatible with USB 2.0 and 1.1, so you'll be able to connect your optical drive to older computers.
Product Description StarTech.com USB 3.0 to Slimline SATA ODD Enclosure for Blu-ray & DVD ROM drives - Portable Optical Disk Drive Enclosure - Solid Aluminum (SLSODDU33B) - storage enclosure - SATA 3Gb/s - USB 3.0
Device Type Storage enclosure - external
Bus Type USB 3.0
Colour Black
Expansion Bays 1 x front accessible - 5.25" Slim Line
Interface SATA 3Gb/s
Data Transfer Rate 300 MBps
Supported Devices CD drive, DVD drive, BD drive
Product Material Plastic, aluminium
Dimensions (WxDxH) 13.6 cm x 15 cm x 2 cm
Weight 277 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
£18.61
