StarTech.com USB 3.0 to SATA or IDE Hard Drive Adapter Converter
£33.88
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: Storage controller
  • Stock Status: In Stock
Product codes
Connect a 2.5in / 3.5in SATA or IDE Hard Drive through a USB 3.0 Port. The USB3SSATAIDE USB 3.0 to IDE/SATA Adapter Cable connects any standard 2.5in or 3.5in SATA or IDE hard drive to a computer through an available USB 3.0 Port (Backward compatible with USB 2.0). The adapter lets you connect a bare drive with no enclosure, saving time and hassle.
The USB 3.0 SATA/IDE Adapter lets you externally connect a bare drive with no drive enclosure or HDD dock required, and features LED indicators that allow you to easily monitor status and activity updates.
The adapter cable works with Windows, Linux, and Mac computers and does not require any software or driver installation - a true plug-and-play solution for adding cost-effective external storage, or overcoming incompatibility between all hard drives and USB enabled motherboards that may not be SATA or IDE-equipped.
The USB3SSATAIDE USB 3.0 to IDE/SATA Adapter Cable comes complete with universal adapter and power cords, providing the additional power required to connect 3.5-inch and larger capacity 2.5-inch hard drives.
Product Description StarTech.com USB 3.0 to SATA IDE Adapter - 2.5in / 3.5in - External Hard Drive to USB Converter – Hard Drive Transfer Cable (USB3SSATAIDE) - storage controller - ATA / SATA - USB 3.0
Device Type Storage controller - external
Bus Type USB 3.0
Colour Black
Interface ATA / SATA
Data Transfer Rate 4.8 GBps
Supported Devices Hard drive, solid state drive
Max Storage Devices Qty 3
Product Material Plastic
System Requirements Linux, Microsoft Windows 2000, Apple MacOS 8.6 or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Weight 54 g
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
£33.88
