StarTech.com USB 3.0 to VGA External Video Card Multi Monitor...
LAST FEW REMAINING
PRICE DROP
StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter for Mac and PC
PRICE DROP!
£65.98
17 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Ensures smooth, High-Definition video content, using a high bandwidth USB 3.0 connection
  • Hassle-free graphics upgrade without opening your computer case, by connecting an external video card to your USB port
  • Stock Status: In Stock
Product codes
Connect a VGA monitor or projector through USB 3.0, for an external multi-monitor solution at resolutions up to 1920x1200. The USB32VGAPRO USB 3.0 to VGA Adapter turns an available USB 3.0 port on your desktop or laptop into a VGA output, with high resolution 1920x1200/1080p video support - a convenient external video solution that makes it easy to add multi-monitor capability to a USB 3.0-enabled Mac or PC (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, and powered by the DisplayLink chipset, the USB32VGAPRO is the highest performing USB to VGA adapter, delivering high-resolution content to your VGA-capable display. The external graphics card can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
Product Description StarTech.com USB 3.0 to VGA External Video Card Adapter for Mac and PC - external video adapter - DisplayLink DL-3100N - 512 MB - black
Device Type External video adapter
Bus Type SuperSpeed USB 3.0
Graphics Engine DisplayLink DL-3100N
Memory 512 MB DDR2
Max Resolution 1920 x 1200
Interfaces VGA
Dimensions (WxDxH) 5.5 cm 2 cm
Length 25.5 cm
Enclosure Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
£65.98
