StarTech.com USB 3.0 to VGA External Video Card Multi Monitor...
StarTech.com USB 3.0 to VGA External Video Card Multi Monitor Adapter with 1-Port USB Hub  1920x1200
£49.03
16 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Keep a USB 3.0 port available on your Ultrabook or slim laptop, using the built-in USB 3.0 hub
  • Enjoy smooth, high-definition video content, using a high bandwidth USB 3.0 connection
  • Stock Status: In Stock
Product codes
Connect a VGA-equipped display through USB 3.0, while keeping the USB 3.0 port available. The USB32VGAEH USB 3.0 to VGA Adapter turns a USB 3.0 port into a VGA output port with 1920x1200 (WUXGA) video support. The adapter features a built-in 1-Port USB 3.0 hub, which offers a connection port in place of the USB port used for connecting the VGA adapter - an ideal workaround for Ultrabook or laptop users where only a limited number of USB ports are available.
Functioning as an external graphics card, this USB to VGA adapter provides a convenient way to add multi-monitor capability to a USB 3.0-enabled desktop or laptop computer (optimal performance from USB 3.0, backward compatible with USB 2.0).
Leveraging the high-bandwidth (5 Gbps) SuperSpeed USB 3.0 interface, the adapter delivers smooth, high-definition content to your VGA display / projector. The adapter can be used to mirror your primary desktop, showing the same image on each display, or to extend your desktop to double your workspace and increase your productivity.
Product Description StarTech.com USB 3.0 to VGA Adapter with 1 Port USB Hub - 1920x1200 - External Video & Graphics Card - Dual Monitor Display Adapter - Supports Windows (USB32VGAEH) - external video adapter - T5-302 - 16 MB - black
Device Type External video adapter
Bus Type SuperSpeed USB 3.0
Graphics Engine MCT Trigger 5 T5-302
Memory 16 MB DDR2
Max Resolution 1920 x 1200
Interfaces VGA , USB 3.0
Dimensions (WxDxH) 4.9 cm x 8.5 cm x 1.7 cm
Enclosure Colour Black
Designed For P/N: MXT101MM
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 t...
£49.03
