StarTech.com USB 3.0 VGA Video Adapter
LAST FEW REMAINING
PRICE DROP
PRICE DROP!
£41.46
29 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Simplify installation while you're on the go, with on-board memory enabling you to install the adapter without a CD-ROM drive or Internet connection
  • Increase productivity by connecting an additional display to your Ultrabook or laptop workstation
  • Stock Status: In Stock
Product codes
Add a secondary VGA display to your USB 3.0 enabled PC, and install the drivers without a CD or Internet connection. This USB 3.0 to VGA video adapter works as an external video card, enabling the USB port on your computer to output video to a VGA display at high resolution. The adapter also features on-board driver installation, which means the adapter will work when you connect it, even without a software disc or Internet connection. For the ultimate in hassle-free installation, this USB video adapter features on-board drivers which prompts for installation as soon as you connect the adapter to your Ultrabook or laptop computer. This means you can maximize portability by never requiring an installation disc or Internet connection to install the device.
Adding a second or third display to your computer can vastly increase your productivity by giving the freedom to access more applications at the same time. This video adapter is intended to support all of your business applications including web browsing. You can also leave your system video card available for more demanding applications such as gaming or CAD design, while you use the USB monitor for reference material. Using the high-bandwidth USB 3.0 interface, this adapter enables smoother scrolling through documents, higher refresh rates and an overall enhanced performance over USB 2.0. The adapter is optimized for use with USB 3.0, but for added compatibility this adapter is also backward compatible with USB 2.0 computer systems.
Product Description StarTech.com USB 3.0 to VGA Display Adapter 1920x1200, On-Board Driver Installation, Video Converter with External Graphics Card - Windows (USB32VGAV) - external video adapter - 512 MB - black
Device Type External video adapter
Bus Type SuperSpeed USB 3.0
Memory 512 MB DDR2
Max Resolution 1920 x 1200
Interfaces VGA , USB 3.0 (male connector)
Dimensions (WxDxH) 2.5 cm 1.2 cm
Length 19.5 cm
Enclosure Colour Black
Designed For P/N: MXT101MM
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com USB 3.0 V...
£41.46
